| Thread Tools | Search this Thread |
#1591 | |
Thats the general idea I was getting , as it dosent mention matching in the F5 article. Looks like imight be powering up a channel later today then ! cheers dave
The luminous space in the Sword of Orion... |
#1592 | |
When can we expect B1 and F5 PC boards. Thank you |
#1593 |
The one and only
You can expect a B1 as soon as the PC fab house gets them done,
probably 3-4 weeks. I have not yet laid out the F5, and do not have an ETA. |
#1594 | |
You got my interest, I have measurement computing DAC's laying all over the place. I also have .net. Tell me more please. |
#1595 |
got my F5 fired up today--1amp fuse, used variac, got to 115v,checked rail voltages +- 26volts-all looked good-turned the pots alternating- 1/2 turn at a time went to .25v 0 offset-all good-put in 1 1/2 sloblo fuse hooked up to speakers and preamp-played music for 1 hour-got warm -turned bias to .40v 0 offset all good-set bias to .59v o offset-did fine.i then bolted the amp all together and hooked to a different set of speakers turned it on and lost the right channel-dang!! took it apart-slightly melted the fuse but still had conductivity.put in 1a fuse and used variac--left channel okay but right has 22vdc offset p-fet has .4volt bias and n-fet has 0 and the pots don't seem to have any effect--what did i blow up?????helppppp!!!!
#1596 |
The one and only
You did not specify your voltages and parts adequately for a
diagnosis, however there is a limited number of parts possibilities. |
#1597 |
i measure .4v across R11 and 0v across R12 when i have the variac at 115v. when i have the variac set at zero and start to increase to 20v the offset increases and the pots have some effect but past 20v the offset shoots up and the pots have no effect-the offset reads 22v when the variac is set to 115v--please tell me what else to measure and i'll sent back the info-thanks mark
#1598 |
Passive Aggressive
Are you connecting your variac to a transformer/power supply of your F5 or just straight to the F5 circuit ?
#1599 |
variac to the complete amp--took board off and had a look around and put back on-have the pots at minimum-turned on the variac when i got to 60-70 volts the offset was at 20v and R1 the 10 ohm resistor was smoking!!!!! that should narrow the search down-any clues to what part is defective? ( besides R1 )
#1600 |
replaced the sk170 -didn't have any 10 ohm resistors but had a bunch of 4.7 ohm
| Currently Active Users Viewing This Thread: 4 (3 members and 1 guests) | |
| Oreda, ce, unixdeveloper |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 11:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 06:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 11:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 09:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 05:06 PM |
| Page generated in 0.17273 seconds (60.35% PHP - 39.65% MySQL) with 11 queries |
