F5 power amplifier
F5 power amplifier
Old 12th January 2018, 01:43 PM   #15791
wdecho is online now wdecho  United States
F5 power amplifier
Mighty Zen, where, how did you find the Iq of 1A6. Like to learn something.
Old 12th January 2018, 03:37 PM   #15792
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F5 power amplifier
took it arbitrary
set what you like .... say to 55C at heatsinks , measure just to be sure that both channels are in same bracket and that dissipation is still sane ( which will be , except in case that you are using Gargantuan size heatsinks)
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 12th January 2018, 04:17 PM   #15793
F5 power amplifier
Originally Posted by Zen Mod View Post
took it arbitrary
Gotcha
Old 20th January 2018, 12:30 PM   #15794
F5 power amplifier
Fired up the F5 but did install .47 resistors but not the current limiting circuit. It is installed on big heatsinks and with .59V bias is running 25C. How high have others biased this amplifier? This is just a project so I am going to turn it up but am just curious how high the other FAB have biased their build. I will turn up till it reaches 55C on the heatsinks close to the mosfets.
Old 20th January 2018, 12:44 PM   #15795
indra1 is online now indra1  Indonesia
Originally Posted by wdecho View Post
... just curious how high the other FAB have biased their build. ...
Find a cozy place of your own somewhere between
Originally Posted by chede View Post
... As a first step I switched the power transformer to 20V secondaries and had rails with 24V-ish voltage, still with the Aleph J. Set bias to 2.0 amps, so roughly 48W per MOSFET, which still worked with my heatsinks....
and here.
I'm not Fearless Amplifier Builder , as Papa certainly is ..... and I'm anyway used to make unnecessary changes to his circuits , so some trace cuttin' and one additional resistor , change of trimpot value , multiturn just because I'm Chicken
And never forget the master FAB principle by Papa here.
Old 20th January 2018, 01:40 PM   #15796
F5 power amplifier
How do you adjust a bandsaw blade. You tighten it till it breaks and then back up some.
Old 20th January 2018, 01:53 PM   #15797
As Papa sez, X*?@! is reserved for the more mature constructor. You absolutely qualify beyond reasonable doubt.
Old 20th January 2018, 02:16 PM   #15798
R.I.P.
I just love this method.
Precisely clear when too much.
regards Andrew T.
Old 20th January 2018, 02:30 PM   #15799
F5 power amplifier
Right now I have the bias up to .9V and it appears to be running cool directly on the mosfets and around the mosfet at the heatsinks. My heatsinks are so big that the are still around 25C. I am yet to see how it sounds but last night I was surprised on how good it sound. I say this because this is one build I have sighed away from because others have said it would be too bright on horns. It was not the case with my horns.
I have plenty of mosfets indra1 so it is not a big deal if I burn up some. Just playing. Whether they last is another matter. I will keep members informed especially on the difference in sound. Supposedly they sound better the more you run them up.
Old 20th January 2018, 02:34 PM   #15800
R.I.P.
Right now I have the bias up to .9V and it appears to be running cool directly on the mosfets and around the mosfet at the heatsinks. My heatsinks are so big that the are still around 25C. I am yet to see how it sounds but last night I was surprised on how good it sound...........
Yet we have a body of opinion insisting that semiconductors must run HOT to perform well.
Run them as cool as you can manage and stay within the electrical parameters required for good audio performance.
regards Andrew T.
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
