F5 power amplifier
F5 power amplifier
Old 17th June 2017, 05:56 PM   #15601
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
F5 power amplifier
The F5 design was released to DIYers when production ceased, and
it's fine with me if people want to generate their own artwork.
The IP involved is simply copyright.
There are pc boards available in the store.
Old 17th June 2017, 06:26 PM   #15602
2 picoDumbs is offline 2 picoDumbs  Australia
2 picoDumbs's Avatar
Originally Posted by peafarmer View Post
Pico, I'm using the Peter Daniels boards. I might be sqeamish, but the boards are so small that I'm not really looking forward to de-soldering. I might just splice in a 12K like 6L6 did for his bias resistors, though. Thanks, guys! Andy
Alternatively just remove the current limiters altogether.
I personally never bother with them.
"If you leave this point unattached to some circuitry, an ideal constant current source will emit a small lightning bolt which will travel until it connects to something." Nelson Pass
Old 17th June 2017, 10:04 PM   #15603
The one and only
F5 power amplifier
I have a nice one where all that stuff is gone, including the Source resistors.
Takes a short while to warm up...
Old 18th June 2017, 04:11 AM   #15604
Me too.
I tweak the source resistors on the input jfets to get around 0.025% 2nd Harmonic on the distortion analyzer.
Extremely bloody good amp like this.
Old 18th June 2017, 04:30 AM   #15605
Hikari1 is offline Hikari1  United States
If I want to take out the current limiting can I simply cut the a resitor lead from r21/r22? My f5 is built with current limiting and its much easier to just snip a resistor lead while it's in the amp instead of taking about the boards and removing the resitors and ZTX devices.
Old 18th June 2017, 04:43 AM   #15606
snip ztx450/550, r17, r18, r19, r20, r21, r22.
Old 18th June 2017, 05:52 PM   #15607
The one and only
F5 power amplifier
Unless you are committed permanently, it is adequate to simply remove
the ZTX parts.
Old 21st June 2017, 08:48 PM   #15608
Thanks for the advice and the amp, Nelson.
Old 29th July 2017, 06:10 AM   #15609
Kosst Amojan is offline Kosst Amojan  United States
Kosst Amojan's Avatar
Total nube rube here... I've got sitting on my table a completed F5 but I've got a problem. I've powered the thing up and tried to set the bias.... and nothing. I can crank the pots to their max and absolutely nothing across the resistors.
A little info about this specific build:
I've opted to run 32V rails. I used boards from DIYaudiostore which are laid out according to the F5 Turbo article. I've built the boards to the design except that I've omitted R15-R18. R19-R20 remain. All the transistors are Linear Systems parts.
In probing around I'm getting power to the boards. I've attached heatsinks to the JFETs and they get slightly warm. I have modest amounts of offset at the outputs (15-22mV+) which also doesn't change regardless of how much a turn pots P1 and P2. I'm thinking based on what I've read that R5 and R6 are too low in value and may need to be increased. Would this thinking be correct? Could R19 and R20 be allowing the current limiting to kick in with the higher voltage? This is my first amp and I'm really a bit lost.
Old 29th July 2017, 09:44 AM   #15610
R.I.P.
If you have built an F5t then try posting in the F5t thread.
Now supply some measured information attached to a pic of your adopted schematic.
regards Andrew T.
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
