Old 25th July 2008, 03:56 PM   #1511
h_a is offline h_a  Europe
h_a's Avatar
This place is called DIY Audio ??
Ja!!
C'mon! One fetish piece of his Passness is a must!
The other zillions of pcbs I've still to do myself.
Have fun, Hannes
By the way: maybe somebody wants to work out a nice jfet only JLH with LU1014 in the output? I have such a feeling that mine will never be finished....
Old 26th July 2008, 11:12 AM   #1512
h_a's Avatar
By the way, could somebody tell me what the limiting factor for the F5's power into 2R is?
Fig. 10 in the article shows clipping at 50W into 2R - at this power the F5 already left ClassA (5 A output current), but didn't not yet approach the rail (10 V output voltage).
What's happenin here?
Have fun, Hannes
Old 26th July 2008, 01:15 PM   #1513
MEH is offline MEH  United States
Safe Operating Area limits of the MOSFETs. At least that's what I take it Papa means when writing: "The amplifier with 24 supply rails should be good for a 50 watt peak into 8 ohms, or about 2.5 amps. For a 4 ohm load we would want 5 amps, and for a 2 ohm load, we want 10 amps. Since we only have two output devices, we probably are best off stopping there."
Old 26th July 2008, 02:29 PM   #1514
h_a's Avatar
No, the current limiting has nothing to do with clipping, the abrupt onset of large distortion.
It's current limited to 10A, so with 5A far away.
Have fun, Hannes
Old 26th July 2008, 06:18 PM   #1515
sandstorm33's Avatar
Originally posted by jacco vermeulen
Actually, i was thinking of using the F5 boards as body jewelry at the nudy beach.
Single Ended, of course.
Hardly expeditious......all that wasted space!
Old 26th July 2008, 08:48 PM   #1516
Nordic is offline Nordic  South Africa
Nordic's Avatar
Has anyone come up with replacements for te 2sk170 and 2sj108... and the one alternative given for each by Nelson?
My boards are 55mm x 130mm, virtualy fully semetrical, with the outputs about 100mm appart.
The 2sj108 and its alternative specificaly seem to be hard to find...
Old 26th July 2008, 10:21 PM   #1517
Nordic's Avatar
oops left out the decoupling caps and Ground, hahaha
Traces were slightly optomised again...
Old 26th July 2008, 10:23 PM   #1518
Nordic's Avatar
and of course the PCB for comments
Old 27th July 2008, 05:52 AM   #1519
EUVL is offline EUVL  Europe
I would perhaps move the power supply connections to the bottom left and right corners to aviod any voltage difference between the common nodes of the MOSFET source resistor and the JFET drain resistors. Also makes it easy to double up to a balanced on one PCB. And for that matter perhaps use a soldered jumper to connect the 10R (for which I use 3x 33R 0.25W in parallel) JFET source resistors to Gnd, which allows you to convert to an X-Balanced later. All options then open.
Otherwise quite well done, I thought.
Patrick
Old 27th July 2008, 07:22 AM   #1520
Nordic's Avatar
Hi thanks for the reply...
I thought about cornering the two power points, but decided to stick with the stared layout giving all components accesing those nodes, connection at a single (reference) point, in the same way you might be used to seeing ground stars. It has the benefit of not makeing high and low current paths shareing the same tracks... (Quieter operation)
I do not see myself going balanced soon, but I will try to find the balanced schematic in this long thread, to get a grasp of what you intended wit the 10R's.
Also, I still need to sim the boards to check dissipation etc, so it will likely still change a little...
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
Dennis Hui, Bksabath
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Page generated in 0.17363 seconds (66.05% PHP - 33.95% MySQL) with 11 queries
