Old 24th July 2008, 07:48 PM   #1481
zinsula is offline zinsula  Switzerland
zinsula's Avatar
Patrick's measurements are very intresting, thank you for the detailed presentation.
From the whole thing, it seems to me that the quite substantial lower transconductance of the P channels MOSFET's will not have major drawbacks because they have also a much higher Vgs threshold.
Therefore, the required higher JFET drain resistor of the upper halve does compensate for this.
Also shown clearly in Patrick's spreadsheet.
My thoughts on better complements here:
http://www.diyaudio.com/forums/showt...36#post1494636
As OT, what would be the consequence in a F4 when using MOSFET's with these transconductance differences? Very high K2?
Tino
Old 24th July 2008, 09:09 PM   #1482
EUVL is offline EUVL  Europe
Tino,
You cannot get better complementaries than the Toshibas, IMHO !!
http://www.diyaudio.com/forums/showt...t=#post1507044
Also the spreadsheet I posted only shows gain balancing, but says nothing about 2nd and 3rd. I have another spreadsheet for that, which is 1.8MB and too complicated to explain. But there, it shows that the Toshibas give half the distortion as the Fairchilds when trimmed properly (to account for the Transconductance differences of the JFETs.)
Not that it is important, whether at 0.003% or 0.006%
Patrick
Old 24th July 2008, 09:15 PM   #1483
May I come back to my question a couple of pages before ?
http://www.diyaudio.com/forums/showt...32#post1567732
>> What would you suggest to flatten the small hump? Gate resistor to 22R does not seem to do much.
> What hump is that?
>> The second plot when the amp is loaded with a dummy speaker load (reactive, about 4 ohm).
Thanks,
Patrick
Old 24th July 2008, 10:15 PM   #1484
The one and only
Nelson Pass's Avatar
I don't know what reactance you have in the load, but you can
induce an arbitrary rolloff with capacitors across the 100 ohm
feedback resistors or at the input.
Old 25th July 2008, 12:30 AM   #1485
MEH is offline MEH  United States
Somebody please remind me again, for use in an F5 topology, what is the reason to choose the IRF or Fairchild MOSFETs over 2SK1530s and 2SJ201s?
Old 25th July 2008, 01:04 AM   #1486
Magura is offline Magura  Denmark
Magura's Avatar
Transconductance.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 25th July 2008, 01:37 AM   #1487
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
2 in parallel have both comparable transconductance and capacitance numbers.
Not so much,.......if it says "ZM" in the corner.
Old 25th July 2008, 01:39 AM   #1488
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
two Pussycats
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 25th July 2008, 01:42 AM   #1489
Magura's Avatar
Go to sleep!
Magura
Old 25th July 2008, 01:44 AM   #1490
You check the transconductance number of the IRF P-channel before you do.
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright ©1999-2013 diyAudio
