F5 power amplifier
F5 power amplifier
Old 5th August 2014, 06:41 PM   #14391
acumos is offline acumos  Italy
Originally Posted by 6L6 View Post
acumos - are you sure P2 is turned all the way down? Counter-clockwise does not ensure it being at minimum resistance, all versions of this PCB have one of the bias pots "backwards"
With power off, adjust pot for minimum resistance measured across R3 and R4
yes 1 ohm
Old 24th August 2014, 08:24 PM   #14392
Bigun is offline Bigun  Canada
Bigun's Avatar
F5 power amplifier
Originally Posted by EUVL View Post
> would it be possible to reduce gain of F5 to say 5db or better to unity-gain?
I had this idea around July last year, and discussed with Nelson.
The worry was (in)stability.
We even did some simulations which shows stability should be OK.
did anybody try a unity gain F5 (and compare with F4) ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 24th August 2014, 08:36 PM   #14393
6L6 is offline 6L6  United States
6L6's Avatar
F5 power amplifier
If you can live with unity gain, build the F4.
Trust me on this point...
Old 25th August 2014, 08:56 AM   #14394
R.I.P.
with +0dB of closed loop gain, there will be an extra 16dB of feedback.
That will probably require major work in determining new/additional stability compensation components.
regards Andrew T.
Old 25th August 2014, 10:31 AM   #14395
leifchristensen is offline leifchristensen  Norway
hello
have built a pair of F5Turbo monoblocks
after months of struggle they´re up and running with choke input psu
bias is 350mA across 1R
32vdc from psu and offset is cruising around +/- 3-4 mv
sink temp is below 50C
yesterday I thought I´d try to replace R2=47K input resistor with a grid choke and the funniest thing happens....the offset goes bananas above 1v and continues so during the warmup period
but the swings rapidly narrows in and finally settles when approaching target bias
will try again tonight, but does anyone have a clue what happens?
the grid choke is 8000H and 1,8mA
not sure about dcr, but probably very low
all input is of interest...
best
Leif
Old 25th August 2014, 10:35 AM   #14396
R.I.P.
could be motorboating.
LF oscillation
regards Andrew T.
Old 25th August 2014, 10:38 AM   #14397
ok
curable?
anybody else tried grid choke in a similar position?
best
Leif
Old 20th September 2014, 03:07 PM   #14398
umut1001 is offline umut1001  Europe
umut1001's Avatar
There was a schematic of f5 amp with 2sk1530 ones with lower voltage.I am searching but could not find it !
"Peace at Home, Peace in the World"
http://stores.ebay.com/Paradise-of-H...dio-components www.hiendparadise.net
Old 20th September 2014, 03:17 PM   #14399
umut1001's Avatar
And it was without protection transistors.
Old 20th September 2014, 03:28 PM   #14400
umut1001's Avatar
I found it but want to make an unbalanced one.Euvl does not guarantee to work it
I want to run 4 ohm speakers with higher class a power.This is why i want to have an amp with lower voltage and higher bias.Normal f5 amp does not give high class a power to 4 ohms as much as it gives to 8 ohms
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
