F5 power amplifier
F5 power amplifier
Old 14th April 2014, 03:20 PM   #13901
dieringe is offline dieringe  Germany
The heating devices should be in the upper region of the heatsink anyway ...
Old 14th April 2014, 03:42 PM   #13902
mfrimu is offline mfrimu
My PCB is mounted on 10mm or 3/8 inch 4-40 metal standoffs directly near the top of the heatsinks. The FET's are on the bottom side of the PCB pointing downwards.
That way my P1 P2 and P3 are easily accessible and PCBs are further away from PSU components.
Originally Posted by Zen Mod View Post
clarify
Old 14th April 2014, 04:27 PM   #13903
Why? I'd imagine the opposite since heat tends to rise.
My concern was if (I doubt) the PCB would get hotter when the FETS are below....
Old 14th April 2014, 04:38 PM   #13904
BobEllis is offline BobEllis  United States
BobEllis's Avatar
mfrimu, you have it arranged for the best efficiency of the heat sinks. The little bit of heating that the board gets from being above the output devices is insignificant.
Old 14th April 2014, 04:46 PM   #13905
Originally Posted by mfrimu View Post
heat tends to rise.
Only with the air, so the hotter area should be at the top
Old 14th April 2014, 06:14 PM   #13906
As of curiosity, why devices at top would be better for heat distribution?
( PS: My devices are a bit lower than half way, not at the bottom... )
Old 14th April 2014, 06:48 PM   #13907
I think I've read that somewhere in Papa's papers, long ago.
As this was counterintuitive to me as well I assumed it was tested and tried to explain it to myself by the better airflow you get if the center of heat is higher and the hottest air leaves the heatsink as soon as possible.
Right?
Old 14th April 2014, 06:55 PM   #13908
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F5 power amplifier
if devices are situated in one row on heatsink , they need to be horizontally on lower third
warum?
darum!
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 14th April 2014, 06:58 PM   #13909
darum!
That's no explanation. Did you try it?
Old 14th April 2014, 07:06 PM   #13910
Zen Mod's Avatar
F5 power amplifier
that's plain logic and physics , which I don't need to prove to anyone
plenty of examples all over the board
just think of temperature interaction of vertically aligned heatsink and airflow and you'll get it
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
