F5 power amplifier - Page 1344 - diyAudio
Old 5th November 2013, 12:18 PM   #13431
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
pull semis from circ and test them separately
search here for mosfet matching , jfet matching
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 5th November 2013, 12:35 PM   #13432
Thanks for the reply - isn´t there an easier way :-)
... It is so nicely assembled, and it is not easy to disassemble.
I have read Pass´s documents on FET matching.
In a tube circuit I would have measured the voltages on all the tube pins, and probably from that been able to diagnose what is wrong. But I can not do that in a FET circuit.
I did search for a schematic with voltages, but didnt find one.
Best regards
Arthur.
Old 5th November 2013, 12:39 PM   #13433
cviller is offline cviller  Canada
cviller's Avatar
Not ideal, but you can do that. The most interesting voltages will be the R3 and R4 - they need to be around VGS voltage (~4V for typical IRFP240). If you cannot get any voltage across those, your input fets are probably not working.
Be prepared for more smoke though...
Old 5th November 2013, 03:05 PM   #13434
sangram is offline sangram  India
You can use a light bulb in series, set pots correctly (fully shorted gate to source, putting output in cutoff - easy to measure). At this time F5 pulls practically no current, not even as much as a Class D amplifier.
Use a variac to bring up the voltage and if the bulb lights, the output is smoked.
Note that as per Mr. Pass the Drain resistors are somewhat optional. If you do not want to smoke your new set and do not want to buy new equipment, I suppose you could try gambling again, but I'm not sure a public forum should discuss such things.
Another easy way to test is with a low-voltage, current-limited power supply to see if the outputs are indeed toast. I think 12V, 1A regulated and current limited supplies should be easily available, or you could simply hook up two computer PSUs, cheap ones, in series - ensure they have working current limiters, set bias to zero and see if the supplies trip at startup. I would think even a single supply should do it is all you're testing is output failure. Just don't put a big honking transformer on it.
I would suggest fuses in the DC line, but I don't know if they will offer protection from fire and smoke.
Old 5th November 2013, 03:52 PM   #13435
Cviller and Sangram,
thank you for your replies. I will check the voltages.
I have no access to a variac, but the other suggestion with the low voltage testing is a very good idea - I have 2 small variable power supplies with current limiting on the way home. 2 because I wanted to be able to make an easy +/- supply.
About the gambling you could be right, but on the other hand I guess most of us are here to learn from other peoples successes and failures, and I am not the first, and I am sure also not the last, who will turn the bias pots the wrong way.
I did read the entire thread once, but never saw a schematic with voltages, which I think is kind of strange.
Best regards
Arthur.
Old 5th November 2013, 04:16 PM   #13436
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
I don't think the variac is needed when using a lightbulb
but do not adjust to full classA with lightbulb
if considered ok and working, remove lightbulb, and adjust
if I remember correctly you should also measure DC when adjusting bias
slowly adjust both bias pots, bit by bit, and keep DC in grip
(hope this is correct)
sometimes we know very little, and sometimes we know too much
Old 6th November 2013, 06:13 AM   #13437
Corpius is offline Corpius  Netherlands
Corpius's Avatar
Yes, that's correct. It is also very well documented in the downloadable build guide
CE-Designs.net
Old 6th November 2013, 06:47 AM   #13438
never seen that pdf file, with detailded build guide ... looks great, thanks
Old 6th November 2013, 11:53 AM   #13439
Arthur, the voltages of interest are all available on the original schematic. The build guide has some typos (it omitted one decimal point in the schematic), look at the original schematic from the website - the owner and service manual for the F5.
All voltages indicated start at zero for the starting setting, and ramp up as you begin to supply gate bias. The three voltages of interest, as has already been stated, are the voltage across R11, R12 and the output. The former two have to be close to 0.6V, and the last to be as close to zero as possible.
Good Luck with your troubles and the gambling
Old 6th November 2013, 12:39 PM   #13440
[IMG]H:\1-Personnel\F5 - In.jpg[/IMG]
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright ©1999-2017 diyAudio
