F5 power amplifier - Page 1340 - diyAudio
Old 12th October 2013, 02:00 PM   #13391
labjr is offline labjr  United States
Originally Posted by BobEllis View Post
The boards from the store's last batch include P3 right next to the input jfets and the thermistors connect between Q5 Source and R12 as shown in the article. Not sure when this was incorporated.
Still shows Rev. 2.0 in the store?
Old 12th October 2013, 02:35 PM   #13392
BobEllis's Avatar
My output boards are V3.0, front end V2.2. I guess Jason needs to update the store's page.
Old 12th October 2013, 02:41 PM   #13393
The F5 is only one board. Are you referring to the turbo boards?
Old 12th October 2013, 03:19 PM   #13394
BobEllis's Avatar
Oops, I am looking at F5T boards. Sorry about that.
Old 12th October 2013, 03:32 PM   #13395
gk7 is offline gk7
Yes I meant the "normal" (not turbo) boards, there seems to be no P3 and the the
thermistor arrangement I cannot deduce from the photo.
Old 28th October 2013, 10:41 PM   #13396
Corpius is offline Corpius  Netherlands
Corpius's Avatar
Today I finally hooked up the amplifier boards to the power supply. Biased both channels without any problems. I kept them powered for an hour or so and re-adjusted the bias. That's when I noticed the transformer humming a bit. I tried swapping hot and cold because that was the easiest thing to try. Any ideas how to get rid of it? I'm using a 300W (Amplimo) transformer. Maybe the F5 is just a bit too much for a 300W transformer, because there was no audible hum when I had just one channel connected.
CE-Designs.net
Old 28th October 2013, 10:58 PM   #13397
crcook is offline crcook  United States
I'm running a 300va 16volt transformer and no humming problems. Check the mounting...
Old 29th October 2013, 04:49 AM   #13398
WalterW is offline WalterW  Netherlands
Probably DC in your mains 230V....
I had the same problem with Amplimo transformers. Read this: Mains DC and Transformers
I build figure 8 in a separate box and no more hum.
Walter
Pass F5, F5Tv3, ACA, Aleph J, DDDAC1794, DCB1, BA3-preamp, VFET CSX1, Pass F6
Old 29th October 2013, 10:13 AM   #13399
my guess is, a little loose windings. 300VA is on the minimum side. and the chances for humming caused by loose windings is greater.
i dont belive its DC. then it would hum with only one ch too.
Old 29th October 2013, 04:31 PM   #13400
nebiki is offline nebiki  Germany
Hello again,
I'm slowly starting to develop the project of building a F5 in my head. I've already come across several problems, some of which I can't seem to solve by reading up on them. I've read the article about grounding by Dave Davenport and did not quite get it. I have huge problems understanding his diagrams.
I understand that for satefy reasons I have to connect the chassis to earth. I've planned on using the schematics for the "First Watt PS 0 R1 Power Supply" which is found in the F5 pdf. Why is the power ground connected to earth and why is a thermistor between them? How do I connect the grounds of the amplifier circuit and the input signal to that ground - a simple wire? I want to have the PS and amp in seperate boxes and since the thermistor between earth/chassis and ground seems to indicate a potential difference between the two I'm wondering if i need to connect both ground and earth with 2 seperate wires to the 2nd box, one going to the chassis and the other going to the ground of the amp circuit.
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright 1999-2017 diyAudio
