F5 power amplifier
F5 power amplifier
Old 27th June 2008, 06:07 PM   #1331
KSTR is offline KSTR  Germany
KSTR's Avatar
.... I get this response for the drain currents at 20kHz (and no speaker load, exept for those "bypasses" of (100R+100R)//(122R+122R). With 8R load it gets even nastier...
Distortion is accordingly high. BTW I tried cascoding the JFETs and buffering the MOSFET gate drive to lessen some capacitive effects, but to no avail. I'm quite puzzled about that behaviour.
- Klaus
Old 27th June 2008, 06:57 PM   #1332
EUVL is offline EUVL  Europe
I don't think we should jijack the F5 thread, so I propose to move the discussion back to Circlomanen's original thread.
Patrick
Old 27th June 2008, 08:02 PM   #1333
Michael Rothacher is offline Michael Rothacher  United States
AudioMaker.Tech
Michael Rothacher's Avatar
F5 power amplifier
I have built and tested such a circuit and I'm working on the article now. I will find an appropriate place to publish once finished.
Old 2nd July 2008, 03:23 PM   #1334
space2000 is offline space2000  Singapore
hi,
i just saw F5 design. wow, very less parts and its easy for me to build.
i have few questions.
Q1 and Q2= can i use IRF9610?
Q3 and Q4 = can i use IRFP240?
is there at output have to place any resister like aleph-3?
how much heat dissipation will be on 50w output? let say i am using 8ohms speaker.
how about the cap for power supply?
thank you
michael
Old 2nd July 2008, 03:32 PM   #1335
udailey is offline udailey  United States
Passive Aggressive
F5 power amplifier
Default TH1 TH2
Originally posted by Nelson Pass
And the value is not critical at that. I also use 3.3K, because I have
a bag of them.
In regards to TH1 and TH2. I would like to use them. I got some wimpy little thermistors from Digikey.
http://parts.digikey.com/1/parts/indexd12209.html
Pretty concerned that these will melt from more than just temp. Do these thermistors see current? I thought I remembered seeing something about TH1 and TH2 needing to carry 10amps, but maybe this is from the power supply. Cant remember and have not seen that reference again. If someone could give me a bit of help I would appreciate it.
Had my FETs backwards. just found that mistake. Going through P2P again to recheck.
Uriah
Old 2nd July 2008, 03:34 PM   #1336
Passive Aggressive
F5 power amplifier
Originally posted by space2000
hi,
thank you
michael
Michael, go to http://www.firstwatt.com/downloads/F5-om_sm-080527.pdf and you will have your answers. Last page is PS.
I used the 12,000uf caps from Steve at ApexJr and they are working great. Only $1.99 each. I used 12.
Uriah
Old 2nd July 2008, 04:54 PM   #1337
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F5 power amplifier
Default Re: TH1 TH2
Uriah
if these two little buggers ever see some substantial current , then something is definitely wrong ......
just use them and do not worry ; did ya see same critters in Papa's amp ? they are probably same looking .
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 2nd July 2008, 05:14 PM   #1338
Passive Aggressive
F5 power amplifier
Thank ya Zen
Old 2nd July 2008, 05:17 PM   #1339
Zen Mod's Avatar
F5 power amplifier
Thank ya Zen
pleasure is all mine , like always
Old 2nd July 2008, 07:24 PM   #1340
chrismercurio is offline chrismercurio  United States
chrismercurio's Avatar
Default Couldn't think of a good place to post this.....
The mods can move it if they need to.
For the amplifier builders:
http://www.diycable.com/main/product...roducts_id=598
has a pretty good deal on transformers. This looks like it might work as an F series transformer if run at 240v. Just an idea,
Chris
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
