F5 power amplifier
F5 power amplifier
Old 24th September 2013, 08:02 AM   #13331
h_a is offline h_a  Europe
h_a's Avatar
Thanks for your kind words - I'm still alive and around
High Octane phono preamp Wiki
Old 24th September 2013, 06:37 PM   #13332
mbrennwa is offline mbrennwa  Switzerland
mbrennwa's Avatar
Hi all
I've got an F5 built by Nelson Pass and bought from Reno Hi Fi. However, I don't use it anymore because I switched to active speakers, and hence I'd like to sell it. The amp works as new and is cosmetically perfect.
Anyone interested?
What's a reasonable price ($2675 new)?
Matthias
Old 30th September 2013, 02:33 AM   #13333
crcook is offline crcook  United States
Default It's alive...the F5
Just put together an F5, my first Class A FET amp. While awaiting shipment of the diyAudio 4U case, I mocked up the amp with a couple of much-too-small heatsinks and a wood PCB holder.
Right channel fired up no problem. With a warmup, got .59v on both 0.47ohm resistors and .000v at the speaker outputs!
Left channel was the problem child. Could not adjust. Touched up a couple of solder joints that look a bit suspect, and reconnected. Biased up without a problem.
All the parts from Mouser and Jameco, small signal FETs from Spencer in Singapore. Used 18g teflon coated wire from local surplus store. Changes from original schematic: the CL-60 surge parts were attached directly on PEM from input to switch. Also, the dual 18v transformer was not in stock at Antec, so I used a 300VA 16v dual secondary instead. With my slightly elevate utility voltage here, I am getting 22.6 vdc at the PS unloaded. OK by me.
The temporary headsinks I am using for this are too small and get hot quickly, so I can only leave the amp on for 3-4 minutes to adjust. Next step is to add music.
Cannot do much more until the cabinet with heatsinks show up. My advice to someone wanting to build an F5 is to CHECK every resistor value before inserting, and set pots to zero ohms while in the board. I recommend putting in two pots first, check value, then add individual resistors after checking their values. Also put a clip-on heat sink for the small transistors/FETs when soldering on the board.
Thanks to all who offered help.
Old 30th September 2013, 02:48 AM   #13334
jameshillj is offline jameshillj  Australia
Use a fan to blow cooling air across those 'sinks until your bigger case arrives (it doesn't need much air to get rid of the heat)
Don't be afraid to run the unit HOT, 55*C is pretty normal around here, as they do sound more detailed and 'smoother' when hotter, particularly in comparison when some people use giant sinks to keep temp below 40*C.
.... my 2 cents
Old 30th September 2013, 04:56 AM   #13335
The build posts I remember said to keep it below ambient + 25c. Not sure what the danger zone is for the outputs. I do have some fans, so I will take you advice when I put music to the amp.
Old 30th September 2013, 05:37 AM   #13336
On one amp build, I used a couple of small 'tunnel heatsinks' that offered free air 0.9*C/W and ran some slow air thru the pair and the sink just got to about +50*C (for a room temp of about 25*C) - in summer, it still ended up cycling at 56*C (+/- 3*C with a computer 'whisper quiet' 6" multispeed fan control.
I ended up using some flexible ducting to exhaust the 'hot air' outside - worked like a charm - still does, as I understand, and never a problem.
Mind you, I always use a dc protection cct with 'turn on' delay and a 'mute' function - simple and safe!
Old 30th September 2013, 05:44 AM   #13337
So, that begs the question, do F5 users have soft start or speaker protection circuits installed? I haven't seen any in the few pictures posted, and NP did not appear to us them in his original manual.
I am concerned that a component malfunction could put DC on the outputs....not good.
Old 30th September 2013, 06:58 AM   #13338
daviddsailor is offline daviddsailor  Australia
Default F5
I have built four or five of these amps for friends. Only one failed and this put rail voltage across one of his speakers. Generally it is the bass speaker that cops it. This particular amp was the only one that didn't have speaker protection because he specifically asked for it to be omitted. Luckily it didn't damage his speaker because as soon as he realised something was wrong he turned the amp off. It is playing russian roulett not having speaker protection IMHO.
Old 30th September 2013, 07:40 AM   #13339
To me, adding a dc protection cct is a 'no brainer' and I'm totally puzzled about this extraordinary reluctance to use such a common sense addition - there are any number of good, reliable, low resistance, etc, etc modules (from Asia, for example) that cost little and work off easily acquired voltages already in the power amp.
For those people that have a 'thing' about possible relay problems, there are quite a few designs availably (also on this site) that use low Rdson power Fets/Transistors and are also quite simple and cheap to build.
To lose a couple of Power Fets, it costs some dollars for replacement matched Fets, and to lose a good quality bass driver will cost a few hundred but with no passive Xover, it can kill those favourite and highly prized midrange driver that aren't replaceable at all.
A good quality F5 will cost you maybe $6 - 800 to build - a good quality speaker will probably cost 10 times that, so why not use some easily added protection.
Now, if you're using simple Cmultipliers in your amp, the +ve and -ve rails often don't charge up at the same rate, so you DO need some delay while they initially charge up, but adding Capacitor Multipliers to the power supply is another story ...
Old 30th September 2013, 11:58 AM   #13340
12B4A is offline 12B4A  United States
12B4A's Avatar
How did that one fail?
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
