F5 power amplifier
F5 power amplifier
Old 8th September 2013, 02:31 PM   #13311
TTo is offline TTo  Finland
I do enjoy. It is a very fine amplifier.
Old 8th September 2013, 02:43 PM   #13312
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
Hi there, having condemned the F5 in previous posts as it really didn't like my far less than sensitive B&W DM683s, I'm now considering building another pair for quite a different application.
I've already got an Aleph 4, which at 100W / Channel is a meaty beast and I'm not giving it up for no-ones money.
I'm considering building a tri-amp active speaker - based on the Wilmslow Audio Prestige Platinum, you will see thread of its build also in these pages.
So, I need 6 x capable amplifiers.
I've already got 2 x D White Hi Quality MOS-FET 100W amps. Not as good as any of the Pass offerings but still very good. I was considering giving them the duty of driving the bass driver (ie Sub 400Hz).
The mid driver (400Hz - 3800Hz) I'm going to give to the Aleph 4.
OK, both those amps are 100W, the tweeter (3800Hz - 40kHz) needs only 10W or so which I thought the F4 or F5 would handle nicely.
Anyone got any thoughts on my thoughts ?
Old 20th September 2013, 10:48 AM   #13313
acumos is offline acumos  Italy
Hi guys I'm following diyaudio build guide, can you tell me if the soft start pcb by diyaudio store can be used in combination with the cl-60?
Old 20th September 2013, 10:59 AM   #13314
Itsmee is offline Itsmee  England
Itsmee's Avatar
You won't need a CL60 in the mains supply if you use the soft start kit.
Old 20th September 2013, 11:43 AM   #13315
6L6 is offline 6L6  United States
6L6's Avatar
F5 power amplifier
I suggest using the CL-60 as shown in the PSU schematic and saving the soft start for a different amp.
Old 20th September 2013, 11:43 AM   #13316
R.I.P.
You can use the CL60, or other Power NTC, instead of fixed value resistor in a soft start.
Do not put power NTCs in parallel. They are OK in series.
I seem to recall that the DIYaudio soft start has the limiting resistors in a parallel arrangement.
regards Andrew T.
Old 20th September 2013, 11:44 AM   #13317
so I can connect the two primaries directly (240v)?
Old 20th September 2013, 03:54 PM   #13318
Itsmee's Avatar
I assume you have two transformers rather than a split primary for 110V (parallel) or 240V (series) operation; you will need a soft start of some description.
I concur with 6L6, Keep It Simple (KISS).
AndrewT's suggestion is also a good one, but only recommend if you have lots of experience dealing with the main supply, defiantly not for novices.
Old 20th September 2013, 04:00 PM   #13319
R.I.P.
As a follow up.
I have a few soft starts and always use series connected resistors in the limiting positions.
I vary between 3 off 20r 5W and 7 off 20r 5W depending on the VA of the transformer.
With any of these I could substitute a power NTC for any single resistor. The more NTCs the better the soft starter.
If I could afford it, I would use CL60 exclusively in my relay bypassed softstarters, but they are just too expensive compared to my 10r and 20r 5W resistors.
regards Andrew T.
Old 20th September 2013, 06:03 PM   #13320
[QUOTE=Itsmee;3639247]I assume you have two transformers rather than a split primary for 110V (parallel) or 240V (series) operation; you will need a soft start of some description.
No, I have a single Antek AS-4218, but to KISS I follow NP and use a CL-60 to connect in series the two primaries. Only another question. The officiale diyaudio guide for f5 builders in the list of materials says CL-60 but in the text sometimes refers to CL-12. I don't understand this passage.
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
