F5 power amplifier - Page 1331 - diyAudio
Old 22nd August 2013, 05:34 PM   #13301
sjhomey is offline sjhomey  United States
Yes kasey197. That is where I will start.
Old 7th September 2013, 08:46 AM   #13302
Default F5 Voltage question
Hi Guys,
I have just built an F5 and it biases up OK with no or very little DC offset once warmed up, and sounds very good with no issues.
However i noticed that when measuring the DC supply to the Amp PCBS i get +21.5v/-21.5v on both my PCBS (I run them as a monoblocks pair)
The offload PSUS give 24.5v (when not connected to the amp PCB and all PSU parts are the same values as papas design except i used smaller value bleeder resistors cuz that's all i had to hand !)
i was under the impression that most people got from 23.5 v to 24v on there creations?-- just wondering if this is an issue-- but it dosent sound like it when listening to music.
thanks boys
johnny
Old 7th September 2013, 09:08 AM   #13303
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
what you have is normal
DC voltage can't be same for unloaded and loaded
when unloaded , pretty much as 1.41 x Vac
when loaded typically as FW amp , then you're in ballpark of 1.2 to 1.25 x Vac
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 7th September 2013, 09:24 PM   #13304
TTo is offline TTo  Finland
I seem to have a problem with the left channel of my newly built F5. I can only get about 0.13V across R11 and R12, when P1 and P2 are set full clockwise. Any advise on how to troubleshoot this?
The right channel seems to be OK with 0.59V across R11 and R12.
Old 7th September 2013, 11:56 PM   #13305
dazed2 is offline dazed2  Canada
If you really set p1and p2 clockwise then its not going to work.
Remember p1and p2 are reversed on the boards . so if you turn one clockwise the other has to turn counterclockwise.
Old 8th September 2013, 12:20 AM   #13306
Since you have one channel working I assume you know the biasing routine. But just in case here is what I have found works best after having done this numerous times.
Biasing should always start with the pots set to zero and and making small turns. You alternate the two pots in the direction that increases bias and keeps DC offset down. You need 3 multimeters connected to the two resistors and the speaker terminals, so you can keep an eye on all three numbers. Set it to about 400mv first and leave it for an hour and then set it to where you want it.
Incidentally if this doesn't work, I would recheck the soldering on the board. My f5 after about a year of flawless operation suddenly started fluctuating bias on one channel. I replaced all the semis on the board as well as the pots. No luck. Finally I just reheated every solder point on the board and that fixed it.
-uv-
Old 8th September 2013, 07:25 AM   #13307
Thanks for your responses.
Yes, I was able to bias the right channel with that procedure.
On the left channel, P1 and P2 run out of turns at about 0.13V across R11 and R12.
I have desoldered, measured, and replaced P1 and P2. They are 5Kohm trimmers as they should.
Any ideas on what to do next?
Old 8th September 2013, 07:38 AM   #13308
Marra is offline Marra  United Kingdom
Here's the link to 6L6's excellent build thread where he had the same problem.Although he was able to bias higher than you have.Hope it turns out to be as simple as changing the resistors.I had to do the same on my F5T build.
An illustrated guide to building an F5
Old 8th September 2013, 08:47 AM   #13309
Thank you Marra and others!
With 10Kohms at R3 and R4, I now have 0.4V across R11 and R12. I will wait for the amplifier to warm up and see if the bias stabilises.
Old 8th September 2013, 01:41 PM   #13310
Good to hear.Enjoy the music.
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright 1999-2017 diyAudio
