F5 power amplifier
F5 power amplifier
Old 21st July 2013, 09:27 AM   #13241
Corpius is offline Corpius  Netherlands
Corpius's Avatar
Most probably asked before, but is it OK to use just one transformer / power supply for two channels?
CE-Designs.net
Old 21st July 2013, 10:06 AM   #13242
AudioSan is offline AudioSan  Norway
yes it is.
Old 24th July 2013, 02:26 PM   #13243
tonimxp is offline tonimxp  Italy
Default How to obtain more warm sound
This is the Papa's Way
"Alternatively, you can increase the value of the Source resistors to 1 ohms,
and increase the value of the feedback resistors from 2 X 100 ohms and 10
ohms to 1 X 100 ohms and 22 ohms.
The lower amount of feedback will warm the sound up, and you can keep
increasing proportional values in the feedback loop if you wish".
Please about Source resistor values is there a correlation with the power out or not?
If yes how it change?
Antonio
Old 25th July 2013, 02:39 AM   #13244
On Hiatus
SY's Avatar
F5 power amplifier
I've removed links and associated discussion of sales of unauthorized knock-offs using stolen IP. If anyone reposts them, they will be put in read-only mode for an extended period- or perhaps permanently.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 25th July 2013, 02:57 AM   #13245
6L6 is offline 6L6  United States
6L6's Avatar
F5 power amplifier
Good call.
Old 25th July 2013, 03:55 AM   #13246
Andersonix is offline Andersonix  Sweden
Andersonix's Avatar
F5 power amplifier
Maybe mods should make a permanent announcement about knock-offs?
Old 25th July 2013, 09:16 AM   #13247
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Dr. Yay Not Too Early. (sir)
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 27th July 2013, 08:20 AM   #13248
superR is offline superR  Netherlands
This question has been asked many times, but since I am having trouble sourcing the 2sk and 2sj's, I am looking for substitutes.
I have read that J175 and J111 should be accepted replacements, but I want to verify.
The same holds for the ZTX's. I can only source ZTX651 and ZTX751.
Are these part ok to use without reducing the performance "greatly"?
Old 27th July 2013, 10:30 AM   #13249
Marra is offline Marra  United Kingdom
F5 power amplifier
Have you tried Spencer.
Old 27th July 2013, 12:57 PM   #13250
jackinnj is offline jackinnj  United States
jackinnj's Avatar
F5 power amplifier
LSK170 is a direct substitute for 2SK170 and is in current production. BF862 is an RF N-Channel device, surface mount and in production. 2N5457, 2N5460 are around from time to time -- they are old parts often with the identification painted rather than lasered or silked onto the body -- pinout is a bit different and gm a lot lower, so you have to match. There are surface mount versions of these in current production.
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
