F5 power amplifier F5 power amplifier - Page 1322 - diyAudio
F5 power amplifier
F5 power amplifier
Old 28th June 2013, 11:11 AM   #13211
I reported years ago about this voltage modulation when the NTC is not bypassed.
It is in the Krell KSA100 Klone Thread.
I could see the output clipping starting and getting worse as the (primary circuit) NTC varied it's resistance in response to varying output current.
It is even worse when powering a ClassAB amplifier.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 28th June 2013, 01:42 PM   #13212
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F5 power amplifier
one thing is 50W A class with oomphteenth watts of B class capability , another thing is 25W A class amp
however , if Pass is using them in all FW products , same as in many PL ones - in exactly same manner , that's good enough in my book , and everything else is in purely academic domain
so - I'm using the same in my amp , if sissy power and A class are in question
in case that I'm going to make more muscular amp , or even having substantial B class capability , I'm going to use relay based soft start , strictly having NTC chain instead of fixed resistors chain
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 29th June 2013, 04:05 PM   #13213
bcmbob is offline bcmbob  United States
F5 power amplifier
FWIW: I ended up using Andrews formula (500 VA X 3 = 1500 / 120 = 12.5 A) and put two 6 A Slo-Blo in the dual fuse inlet. That prevented the blown fuses. I re-installed the thermistors and found no degradation of of sound quality. I did remove both F5 modules and test them on a chunk of standard heat sink. The output on each was back up to the proper level and that remained when I reassembled the entire amp build. The "starved" distorted sound probably had nothing to do with the CL-60, but rater some fault in the connections. I'm actually now getting the best sound quality and highest output since the beginning of the project. Might try to lower the fuse size back down a bit to increase safety margin now that I know the thernistors are working as designed.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 30th June 2013, 04:14 PM   #13214
LucasAdamson is offline LucasAdamson  United Kingdom
LucasAdamson's Avatar
What do you all make of the DIYAudio soft start and speaker protect boards?
Lucas
Old 30th June 2013, 04:57 PM   #13215
Renron is offline Renron  United States
Renron's Avatar
The CL60s have the ability to reduce the current at startup due to being "cold", perhaps mounting them on/near the heatsinks would minimize their potential of starving the amp when warmed up? Just a thought.
Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
"I fired up the prototype. Literally." The Prophet Pass.
Old 30th June 2013, 04:57 PM   #13216
labjr is offline labjr  United States
I wouldn't put a relay between the output and the speakers.
Probably not a bad idea to bypass the thermistors with a relay after a short period so they cool down.
Old 30th June 2013, 08:24 PM   #13217
Even if the relay is very high pressure connection, and very low resistance?
Lucas
Old 30th June 2013, 10:58 PM   #13218
I wouldn't want anything in the signal path. What you do is up to you. Try it and listen.
Old 1st July 2013, 12:47 AM   #13219
Andersonix is offline Andersonix  Sweden
Andersonix's Avatar
F5 power amplifier
K.I.S.S. and use the NTC. Then experiment later when you have nothing better left to tinker with. I will be experimenting with the attached AC relay type ss (as attached Fig.2) one day, so I will leave some space in my next amps.
Old 2nd July 2013, 09:13 PM   #13220
Jallhalla is offline Jallhalla  Norway
Hi guys,
Some questions that are stupid and certainly asked before, but the answers are hard to find due to the amount of info:
Where do I put the cl60 when there is only one primary winding? In series after the switch and mains capacitor i guess, but just confiming here.
What do I do with signal ground? Im doing this p2p, so its not given by the board and wiring sketches. They are obviously connected together at two points in the circuit itsfelf, but does it go chassis or psu?
Thanks a lot. Will be providing pictures to redicule soon!
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright ©1999-2017 diyAudio
