F5 power amplifier
F5 power amplifier
Old 27th June 2013, 09:53 AM   #13191
LucasAdamson is offline LucasAdamson  United Kingdom
LucasAdamson's Avatar
Originally Posted by AndrewT View Post
I find it difficult to believe you have missed all the references to soft starting and close rated fusing and all the other references to normal transformer fuse rating when a soft start is not adopted.
Fuse value for a transformer or motor ~ THREE times the VA rating divided by the supply voltage.
For a 300VA the fuse required for long term reliable "no blow" start ups is 3.75A use either 3.15A or 4A.
If you adopt soft starting, then you can get away with T1.25A, if you select an appropriate current limiter value for close rated fusing.
Ahhhhhhh! Now that's useful! The First Watt General Power Supply simply states that it must be a 1.25A fuse, and no other information is given.
I will use a 3.15A fuse and hopefully be done with it, as the amp is silent and works perfectly in all other regards. Many thanks.
Lucas
Old 27th June 2013, 10:05 AM   #13192
R.I.P.
How much current will that 3.15A fuse pass without blowing for say 30minutes while you are at the front door trying to persuade some unwelcome caller they are not wanted?
I always recommend close rated fusing. That almost always requires adoption of soft start.
regards Andrew T.
Old 27th June 2013, 12:04 PM   #13193
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F5 power amplifier
naah ........
Lucas could just put nail instead of fuse
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 27th June 2013, 12:25 PM   #13194
Are you suggesting that 3.15A will not protect anything in the event of a surge, for example, by being too nail-like?
Lucas
Old 27th June 2013, 12:29 PM   #13195
Zen Mod's Avatar
F5 power amplifier
NP is putting CL60 as soft start in his commercial products , meant to be both bullet and idiot proof as much they can ;
is that something telling to you ?
with one CL60 in line , I'm using T4A on 800VA Donut , combined with 8x33mF , in one of my amps , on 220Vac line
never had fuse failure , even in case of black-out ( worst case scenario for sole NTC based soft start)
Old 27th June 2013, 01:27 PM   #13196
bcmbob is offline bcmbob  United States
Again, Please see my earlier post.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 27th June 2013, 01:34 PM   #13197
But all seems to be solved by simply adding the higher value fuse. Why complicate things? My amp has nowhere near your huge transformer, or capacitance, and I have a smaller fuse, and all is well.
Lucas
Old 27th June 2013, 01:41 PM   #13198
R.I.P.
The 3.15A fuse should stop the cable feeding a faulty F5 from setting fire to the house.
I don't like that. That's why I prefer close rated fusing.
regards Andrew T.
Old 27th June 2013, 01:44 PM   #13199
Just Sayin'
Bob M.
Old 27th June 2013, 02:19 PM   #13200
valvesound is offline valvesound  South Africa
valvesound's Avatar
Hi guys...a question on a different topic.
What is the lowest input impedance the F5 can have and still operate properly? Typically it is either 100k or 50k....what about 1k???
Don't be concerned about the pre-amp having to drive the 1k load....Just consider the F5 here.
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
