F5 power amplifier - Page 1311 - diyAudio
Old 12th June 2013, 07:04 PM   #13101
LucasAdamson's Avatar
So, my F5 is built and working beautifully!
The amp is velvety silent and sounds great!
One thing that concerns me - everything is a lovely cool temperature, except the heat-sinks of course, which I can touch for an indefinite time, and even the mosfets I can touch for as long as I like, BUT, the bias resistors, the 3W 0.47R Panasonics, raised off the board to aid cooling, are as hot as hell to the touch. Is this normal?
Lucas
Old 12th June 2013, 07:14 PM   #13102
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
yup
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 12th June 2013, 07:19 PM   #13103
Thanks ZenMod.
Is 3W a bit of a mistake then? Wouldn't it be better to parallel up two 1R 3 watters to make a 6w .5R?
Lucas
Old 12th June 2013, 07:49 PM   #13104
Zen Mod's Avatar
P= I^2 x R [W,A,Ohm]
if dissipation is under 50% of resistor rating , I'm calling it idiot proof
with Iq of 2A , P= 2^2 x 0R47= 1W88 , not exactly idiot , but still bullet proof
Old 12th June 2013, 07:52 PM   #13105
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
look out for color changes(darkening)
should be ok if it keeps its natural color
Old 12th June 2013, 08:52 PM   #13106
bcmbob is offline bcmbob  United States
Speaking of heat, I managed to get my Peter Daniels PS where I can detect the temps. The rectifiers are blazing and the resistors are way above ambient. I hadn't noticed that on earlier configurations. Anything out of order here?
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 12th June 2013, 09:05 PM   #13107
My rectifiers are perfectly luke warm. I am using ST BYW99W200 diodes - well over rated and superb specs. Recommended, if you need to upgrade! Nelson Pass likes them too, so you'd be in good company.
Lucas
Old 12th June 2013, 09:08 PM   #13108
6L6 is offline 6L6  United States
6L6's Avatar
Bob- The diodes should have heatsinks.
Old 12th June 2013, 09:13 PM   #13109
Yes indeed, you do need sinks - direct connection to 3mm aluminium casing is sufficient, but mica washers and goop required if you do down that road. Big Chief individual sinks are also good, and have intrinsic electrical isolation (unless they touch each other). Are those MUR 820 diodes? Are they under-rated? Are those resistors 3w or greater? They aren't the recommended Panasonic metal film ones, but maybe that's not important. I find that soldering them away from the PCB helps cooling potential considerably.
Lucas
Old 12th June 2013, 09:17 PM   #13110
O.K., I'll put some on. I'm using Fairchild Stealth. Should those mentioned above be considered an upgrade?
Bob M.
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright 1999-2017 diyAudio
