F5 power amplifier
F5 power amplifier
Old 5th April 2013, 12:26 PM   #13031
AudioSan is offline AudioSan  Norway
2 in series pr rail can handle the 24V rails
Old 5th April 2013, 12:37 PM   #13032
permaneder is offline permaneder  Germany
...and will halve the capacitance...
Old 5th April 2013, 12:55 PM   #13033
rade95 is offline rade95  United States
Originally Posted by danny_66 View Post
Changing the feedback resistors to 220ohm will not only change the gain but also how the F5 sounds and I didn't like that.
There is a forum topic called F5 Listening Impressions started by Bear and this has lot of comments and suggestions about all sorts of mods, including feedback changes and how it affects sound. In fact I think it would be really cool to start a new topic called "F5 mods and such" and have a table that F5 builders could fill in to say what mods they've made (FB, JFETs, BIAS, outputs, PS, etc etc) and what listening experience they've had with those changes in comparison with the stock amp. Also what music source, pre-amp, speakers and enclosures volume they've had and how big the listening room was. I think lot of people would be interested to see this. There were lot of mods made and it would be nice to have it all summarized in a single place.
UGS pre, stock F5, PassLabs X2.5, Aleph P
Old 5th April 2013, 01:05 PM   #13034
yes. but i don't realy see a problem With "only" 1.5F pr rail.
and one may want to have a CRC supply. then there will be 3F pr rail.
but i would not use this kind of caps
Old 5th April 2013, 01:20 PM   #13035
bnorrish is offline bnorrish  United States
bnorrish's Avatar
You need some major neon lights to go with those caps.
Old 5th April 2013, 01:38 PM   #13036
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Your transformer and rectifier bridge will.
Old 5th April 2013, 01:49 PM   #13037
not more then with 3F pr rail
and this is why i also said that i would not use this kind of caps.
Old 5th April 2013, 01:53 PM   #13038
R.I.P.
How long should we expect 1.5F or 3F capacitors take to charge up?
What maximum current should we set for the charge current limiter?
Where best to fit that charge current limiter?
Can we start using the amplifier when the capacitor charge has reached 50% of final voltage or 70% or 80% or 90% or 95% or 99%?
regards Andrew T.
Old 5th April 2013, 02:33 PM   #13039
Not exactly less either.
If one jumps off a cliff, whether the drop is 1500 or 3000 feet, is of no importance, only the edge is.
What does matter is how those cheap car things are constructed.
Reliable lytic brands manufacture caps in a 20Vdc (to 25) rating, three times lower ESR, with value numbers of 1F and above.
But they charge at least five times the retail of a China transgender. (Digital my A..)
Either way, charging 2x1.5F total or up by a conventional setup sounds scary.
Old 5th April 2013, 02:49 PM   #13040
acctualy. the important thing in that case will be when the chute opens
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
