F5 power amplifier
F5 power amplifier
Old 14th March 2013, 11:22 AM   #12961
jcastellano is offline jcastellano  Spain
F5 power amplifier
Default Soldered before installing in the sink
Originally Posted by AudioSan View Post
i would not use the amp until the thermal coupling is corrected.
did you mount the outputs to the sinks before or after you soldered them?
I soldered the outputs and then made the hole.... But there is plenty o thermal grease and also mica insulating... Maybe the thermal grease is not good enough?
I am going to wait until the new tranny arrives from antek and is it rated at the stock F5 values of 18v secs.
Jorge
Old 14th March 2013, 11:33 AM   #12962
AudioSan is offline AudioSan  Norway
that can be the problem. always Mount the outputs before you solder them, to get a good coupling to the sinks.. and there chould not be alot of thermal grease. just a extremly thin layer. thermal grease have a lot of thermal resistance.
Old 14th March 2013, 11:45 AM   #12963
F5 power amplifier
Thumbs up Ok. I will try to fix this...
Thanks... I will try to clean the grease and apply a new thin layer. Desoldering the output is a little more complicated but I will see if it can be done without damaging the output....
Jorge
Old 14th March 2013, 02:38 PM   #12964
McQuaide is offline McQuaide  United States
I had excellent results with my F5 using these pads:
http://www.bergquistcompany.com/ther...0S_12.08_E.pdf
And there's no messy grease involved either.
Old 14th March 2013, 04:10 PM   #12965
sangram is offline sangram  India
Hi
I used mica and grease too, and the first mount delta was 14-15 degrees second mount was 11-12 degrees with about 35W (I ran it a bit hard because I had good sinks).
I used a razor blade to separate the sheets of mica and *very carefully* used the thinnest I could find. I also used Arctic Cooling MX-2 because regular grease is quite bad over here, and I used very, very little on each side of the mica. It wasn't a layer as much as a kiss.
The point is get it so thin that it is just filling the air gaps at a microscopic level. The actual heat conduction is by direct physical contact. You don't want the surfaces to stay insulated from each other by the grease, which is the problem with too much of it.
You can also try a bar over the outputs and torque it down to squeeze out every last bit of contact patch, this will help a lot with single-hole devices being asked to deliver so much.
Good Luck.
Jorge
Old 14th March 2013, 04:43 PM   #12966
Originally Posted by sangram View Post
Hi
Good Luck.
i use MX2 as well a very good grease and Nice price
Old 15th March 2013, 02:41 PM   #12967
Jallhalla is offline Jallhalla  Norway
Hi guys!
Im collecting parts for an F5 now. Most is in the mail at the moment. Painful.
Still, I have not decided how big/many resistors I should have in the psu.
I have a 400va 2x18v transformer, and 14x6800uf caps. And I have a macbook, so I cannot use the duncan software.
Any suggestions?
Old 15th March 2013, 03:08 PM   #12968
jameshillj is offline jameshillj  Australia
Depending on the quality of the caps, suggest 6,800uF - 0.1R - 2 x 6,800uF for each rail, per channel (ie, 12 of those 6,800uF caps in tota) - if only the 1 pair of 18v windings, still use a seperate 4 diode bridge for each channel.
Old 15th March 2013, 03:13 PM   #12969
studiostevus is offline studiostevus  Netherlands
Or use duncan's under crossover on your Mac... That's what i do
TDA1541a-S2 / 6072a / MediaplayerDac -- Michell Gyrodec -- Aikido Preamp -- Pass F5 -- Audio Physic Tempo 2SE -- Yamamura Cabling
Old 15th March 2013, 11:04 PM   #12970
CanAm Man is offline CanAm Man  United States
Jorge
This might help. You don't necessarily have to REMOVE the output transistors. If you already have them mounted, then simultaneously heat all three of the PCB solder pads for each MOSFET (you might have to use two soldering irons, and enlist the help of a friend). The trick is to "reflow" the existing solder, to allow the MOSFET to seat itself on the heatsink/grease while all three transistor pads are molten.
Don't remove the MOSFET unless you must--it's a lot easier just to reflow the existing solder....and it will save the wear and tear on the PCB pads.
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
