#12881 |
speaker terminal ground goes nowhere else, other than the speaker negative
but the signal RCA shield connects to other electronics grounding 'point' I think that should be the main 'concern' |
#12882 |
Not so much,.......if it says "ZM" in the corner. |
#12883 |
Hahaha Jacco, I must say I haven't seen my wife a lot lately...
![]() Building this amp sure takes some time... |
#12884 | |
I don't know if I can use only one bridge, cause I have two separate main audio grounds. Or should I connect those first and then go through one bridge to earth? Hmm... The schematic is attached, it's from the F5T. Only twice in my case; for each ampboard one PSU. Thanks for the compliment ! I will post more. Grtz, Walter |
#12885 | |
#12886 |
The one and only
Build it with cascoding. Easy to do.
#12887 |
any reason why the diode bridges diodes are connected in paralel as one bridge, instead double bridge ? (or am I seeing it wrong)
#12888 | |
The one and only
You can't configure them as a standard 4 connection bridge, so you use them in parallel.
#12889 |
Haha Tinitus, and I'm using those 'special audiophile rectifiers'
![]() You can see them in my picture, the ones with little heatsinks on them... Initially I bought the 35A/200V rectifier bridges, untill someone told me to use the special diodes. That's why I'm having 2 ground loop breakers
#12890 |
ah, ok, thanks
I have used 8 of them per mono amp but never noticed each consisted of two diodes in paralel |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 10:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 08:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
