F5 power amplifier
F5 power amplifier
Old 23rd January 2013, 05:39 PM   #12841
labjr is offline labjr  United States
Originally Posted by jacco vermeulen View Post
Because Japanese manufacture for Japanese.
You are American, not Japanese, reason why it's a bit harder for you to understand.
(eer, my shorts feel like there's a third one residing within the premises, and it's a biggy)
Really, Well just who was using those JFETs in the Japanese market?
Old 24th January 2013, 11:36 AM   #12842
slungu is offline slungu  Germany
Originally Posted by sangram View Post
The input FETs are not safe above 30V or so. You will need a cascode.
It will work fine if you use the cviller F5c boards and use just one output pair. Keep dissipation within the 30W target per device and you will be fine.
400VA sounds about right as a universal power supply.
Ok, I read about it in the art_f5_turbo.pdf, so basically I could go plain F5 at risk, or try a variant with cascode like the input part of V3 and maybe a higher gain while lowering the bias. That would give me more power, but it will leave Class A earlier, if I understood it correctly. Point is I don't want a monster heatsink that would be required in order to go up in Class A power, so I would sacrifice that for more power in the cases when it's needed.
Regards, Stefan
Old 24th January 2013, 12:08 PM   #12843
udailey is offline udailey  United States
Passive Aggressive
F5 power amplifier
How about a small fan plus small-ish heatsink?
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 24th January 2013, 12:35 PM   #12844
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
The answer would be shorter had you asked who wasn't.
The Japanese industry is highly interlinked, both through tradition and long term contracts (which often also have historic links).
On top of that there are huge conglomerates in Japan.
Take e.g. the Mitsubishi corp., everything from banking & insurance, to consumer electronics and parts, to cars and building oil tankers(MHI).
Suppose Toshiba transistors developes a part for Toshiba consumer electronics.
After an average manufacture span of 20 years, Toshiba transistors will develop a successor part, and the old one goes obsolete.
If Toshiba consumer electronics has no need for a successor part, the old one goes obsolete and no replacement.
Even if production of the old part may still be profitable for the foreign market, Toshiba will halt manufacture.
A US company also primarily developes a product for the local market, say Motorola.
It will also start selling abroad once the local market has reached maturity.
The American company will continue manufacturing till total volume of both domestic and foreign demand has dropped to a level that's not worth the effort.
In Japan, the communication path between JFET manufacturer and JFET end user is short, and highly interactive, within a conglomerate as well as between e.g. Toshiba and Sony.
They make both The part for A market, and vice versa, but not just A part for A market.
The JFET numbers have been available in the west for quite a long time.
I can give you plenty examples of Japanese devices that were barely available abroad, with room for growth, when manufacture was terminated.
Old 24th January 2013, 01:52 PM   #12845
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F5 power amplifier
and you , cheapskate , have them all .......
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 24th January 2013, 07:26 PM   #12846
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
F5 power amplifier
There is too much concern about these particular Jfets for the front end
of the amplifier. Yes, the 2SJ74 and 2SK170 are really superb, particularly
on the noise front, but this is not as important when we are already dealing
with line level volts instead of millivolts.
You can still get the Fairchild J174, J175, P1086 P channel devices from such
places as Digikey and Mouser, and they are cheap.
The N channel are even easier to get, such as the Fairchild J111. Worst
case you might have to parallel two, but even that is unlikely. You might
have to select them, but at prices like $0.11 for quantities, you can hardly complain.
Better buy them before I do....
Old 24th January 2013, 07:38 PM   #12847
I had thought there were no parts which could match the performance of the 2SJ74 and 2SK170? I mean we don't want close performance. We want equal or better.
Old 24th January 2013, 11:05 PM   #12848
Renron is offline Renron  United States
Renron's Avatar
ROFLMAO
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
"I fired up the prototype. Literally." The Prophet Pass.
Old 25th January 2013, 12:01 AM   #12849
6L6 is offline 6L6  United States
6L6's Avatar
F5 power amplifier
You can still get the Fairchild J174, J175, P1086 P channel devices from such places as Digikey and Mouser, and they are cheap.
The N channel are even easier to get, such as the Fairchild J111. You might
If selecting, we should be aiming for an Idss of 8-10 or so?
Old 25th January 2013, 12:11 AM   #12850
Don't seem like there's many left. We're like a bunch of crackheads.
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
