F5 power amplifier
F5 power amplifier
Old 15th January 2013, 11:48 AM   #12821
necplusultra is offline necplusultra  Canada
Thanks root2.
May consider your products in the future.
I've been researching this ssr relay and its specifications concerning high inductive transformer startup and zero crossing and all. It talks about resolving the issue with a suppressor diode. (don't know what product to buy nor where to place in circuit) There are also better SSR products more suited for tfo startup. The one I am using is probably not suited for such purpose but it does work well for 1 F5 Power supply. I am not familiar enough with the subject matter so I am tending to go the coil relay route.
what I've tested with SSR relays (120v 40 amp version):
1 relay for 1 f5 ps --->> OK results
1 relay for 2 f5 ps ----> noise problem probably caused by what root2 is stating
2 relays in series for 2 f5 ps ---> noise problem present
I haven't tested 1 relay for each f5 PS but I suspect that this would be OK but I'm doubling the already expensive crydom components.
Also, I have seen higher rated crydom products (H1 series fo which I believe that probably would work).
I will use the ssr for my dac project so its not a lost cause.
thanks all for feedback.
Old 19th January 2013, 01:19 PM   #12822
crydom ssr hum on tfo resolved
I noticed that the coil relay functionned with no hum and the ssr experienced a hum on the transformers in a dual mono config.
The Live wire was going through the relay and to the 2 tfos in parallel. I changed that to serial and hum was no more when going through the ssrClick the image to open in full size.
Old 19th January 2013, 06:00 PM   #12823
sorry fro the bad info
that did not work.
no hum but only half the voltage.
So I'm going back to coils. will try to find an appropraite zero cross ssr relay.
Old 20th January 2013, 05:21 PM   #12824
Root2 is offline Root2  United Kingdom
Root2's Avatar
that did not work.
You could still use a SSR so you get Zero crossing and the in parallel with it
run relay, the relay will take longer than 10-20ms to operate but will not be killed by the inrush, now using a Snubber and still having the SSR on switch the relay OFF then the SSR lets say 60mS later should solve cross over hum and inrush.
A good SSR will not be open circuit until one complete cycles and at about 1.4V below zero volts.
Have fun
Old 20th January 2013, 11:36 PM   #12825
moonLeo is offline moonLeo
Smile psu concerns
Hello,
I need your opinion about a psu.
I'm trying to make a psu for F5 using many components from my box.
the transformer is a 45vac output that give around 64v avec diode bridge.
Using virtual ground each side is near 32v. the bleeders resistor is ok.
the main problematic is on the PI resistor.
As the target is 24v,I have to drop near 8volts if I'm right.
As described in nelson pass f5 manual, 24volt for 6amp continuous and more than 10amp for peak.
In this case, for drop 8volt in 6A, near 1.33 ohms is needed. and using 1.33 ohms in 10amp peak, the voltage drop will be near 13.3 volts... seems too much!!!
So regarding this problem, do you think that I have to use regulator, or using the right resistor value will be ok ?
About regulator, i'm thinking of using lt1083, or see in zen variations #5 as nelson pass recommends.
About resistor, what do you think about the use of bigger capacitors to reduce the problem?
thank you for your help
Old 21st January 2013, 12:07 AM   #12826
6L6 is offline 6L6  United States
6L6's Avatar
F5 power amplifier
To be honest, the best action is to purchase the proper transformer for the F5.
Use the transformer you have for another project.
Old 21st January 2013, 12:54 PM   #12827
kcray is offline kcray  Indonesia
Hello fellow DIYers,
I am about to build a stock F5, just reach page 1052 of this thread.
Wish me luck.
Hope Papa someday would bring us an alternate solution for input stage circuit, since genuine 2SJ74 is getting more more difficult to source.
-- Peter
Old 21st January 2013, 04:23 PM   #12828
Renron is offline Renron  United States
Renron's Avatar
Lineal Technologies says their about to introduce a substitute.
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
"I fired up the prototype. Literally." The Prophet Pass.
Old 21st January 2013, 04:55 PM   #12829
"LSJ74" presumably, is long overdue. Not sure anymore whether the Linear Systems would really release it.
Old 21st January 2013, 05:18 PM   #12830
flg is offline flg  United States
flg's Avatar
I heard some of us have had some in hand! Maybe at BAF last fall???
At any rate, they are still available ju$$t a few dollars more
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
