F5 power amplifier
F5 power amplifier
Old 14th January 2013, 11:12 AM   #12811
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F5 power amplifier
wtf is crydom ssr ?
why don't you ask those who made it ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 14th January 2013, 11:19 AM   #12812
necplusultra is offline necplusultra  Canada
solid state relay is wtf it is.
I've been reading Crydom doc and specifies to bi-pass the load with a diode suppressor
wtf is a diode suppressor and where do I bi-pass the load?
I'd also assume that perhaps, a member already has this kind of setup and would share here.
Old 14th January 2013, 11:27 AM   #12813
Zen Mod's Avatar
F5 power amplifier
wtf is beacuse is easy to put link , to give necessary info
suppresor diodes are sort of bidirectional zenners , and their role is to cut/swallow high voltage spikes
same role as varistors , if memory serves me well
anyway - clarify difference between your "stereo" and "dual mono " ?
meaning one vs. two xformers , or one xformer in both cases but one vs. two C banks ?
in both cases it seems that either load is too much or too much inductive ;
in later case suppressor can help
Old 14th January 2013, 12:49 PM   #12814
I always thought dual mono was like 2 monoblocks in the same case.
stereo is 2 channels powered by one tfo , 1 rectifier and one ps bank.
Nonetheless, yes, I am swithching on 2 tfos, 2 rectifiers and 2 ps banks for 2 F5 channels with the same crydom relay which is speced at 40amps so I think it can handle the load.
I'll continue my research
thanks for input.
Old 14th January 2013, 01:20 PM   #12815
Zen Mod's Avatar
F5 power amplifier
yes , dual mono is two completely separate amps in common case ;
I just asked for clarification what you meant exactly
Old 14th January 2013, 07:13 PM   #12816
sangram is offline sangram  India
I wouldn't use SSR for high power transformer/motor loads. The switching devices don't like those.
You can get away by over-rating the SSR about 100x. I use a 30A device to power up a small 400W Class AB subwoofer amp. I still do get some noise at turn-on and turn-off, but it's worth it for the convenience.
Why exactly are you using the SSR and not a big switch? A single 10A switch is sufficient for two channels of F5 including the heavy inrush current.
Old 14th January 2013, 10:22 PM   #12817
Tried with a 10a switch without any issues.
Its the ss relay that gives problems and I'm using it to have a push button switch at the front of the chassis. Though I may have to revise my plan.
also, Can I use the SS relay if use a soft start circuit?
regards.
Old 14th January 2013, 11:24 PM   #12818
regards.
I don't think a soft start will protect the SSR and transformers from each other.
You can use a regular mechanical relay, you need the latching type. Or simply use the pushbutton to momentarily power a relay that turns the amp on, as well as a second relay that bypasses it. That's two relays, but if your pushbutton can take it, you could probably power up the amp itself through it.
Old 15th January 2013, 12:17 AM   #12819
jameshillj is offline jameshillj  Australia
Crydom have been making various SSRs 'forever' and I'm sure this problem has occurred before and that there's a simple solution in their company information centre.
We used a simple 'work-around' ccts for our own SSRs some years ago, and from memory, it centred about controlling the 'back emf' from multiple lighting transformer loads, avoiding false triggering, filtering induced circuit noise, etc (in the entertainment industry) - it was over 30 years ago, but I'll see if I can find the info.
Old 15th January 2013, 07:31 AM   #12820
Root2 is offline Root2  United Kingdom
Root2's Avatar
Greetings,
Has anybody had any success powering up an F5 through a crydom ssr.
When I connect the relay to the 1 tfo for stereo output, no problem, when I connect relay to a dual mono configuration, the tfo's produce noise.I mean physical hum on the tfos themselves. The dual mono is just the same as stereo except I split the channels with their own ps. When I power through the on-off switch directly connected to the fuse, I get no noise. I read that the crydoms don't like high inductive loads. Since this is touching mains 120V, I'd like to have expert advise.
Does any one know how to resolve this?
kind regards.
The Buzz you often hear when transformers are controlled with SSR or Triac or Back to Back Thyristors is due to the Zero Crossing Point not being Zero, it like cross over distortion.
This distortion also presents itself as EMC induced on to the power supply and is filtered Crydom have used there same basic design since Philips designed it in the early 1960's and taken up by IR and others.
The design can to be produced to reduce the level of EMC and distortion to a level that falls within the EMC specification mentioned below.
More info on this can be found here ROOT2 Limited - LOW NOISE SOLID STATE RELAY
The patent mention is one I did a few year ago, I am about to rethink the whole thing again.
http://www.my-hiend.com/vbb/album.ph...chmentid=14829
So that WTF is a SSR
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
