F5 power amplifier - Page 1274 - diyAudio
Old 11th December 2012, 11:23 AM   #12731
Epcos by any chance?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 11th December 2012, 03:31 PM   #12732
is it possible to build a power supply for the F5 with a transformer that have only one secondary. I already have one 700va
I saw some schematics that create a virtual 0V and have symetrical supplly using only one secondary. Is there any risk at this power ?
regards AQ
Old 11th December 2012, 03:41 PM   #12733
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
search for Quad 606 and 909 schmtcs for recipe
no risk
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 11th December 2012, 03:47 PM   #12734
6L6 is offline 6L6  United States
6L6's Avatar
moonLeo - if your transformer has a centertap, you can do it like this -
If no centertap, see the QUAD schematic as ZenMod suggested, you need to make a virtual centertap.
Old 11th December 2012, 04:27 PM   #12735
Thank you for your replies
The transformer has 3 secondaries, 10v at 1.5A, 20v at 1A and finally 45v at 15A.
As zen mod said, I found into the quad 606 service data manual this :
I'm thinking of connecting these outputs to the psu board of diyaudio store: V+to D+, GND to D- and D+1, V- to D-1, as the gnd is already created.
Do you think it can run well ?
regards AQ
Old 11th December 2012, 04:53 PM   #12736
you have not attached your pic.
The 45Vac should give ~60Vdc.
This can be used with a virtual Earth to give ~+-30Vdc
Or you can use it as a single ended supply and capacitor couple the input and capacitor couple the output.
regards Andrew T.
Old 11th December 2012, 05:09 PM   #12737
Sorry for the picture, this can be better :
thank you for the reply AndrewT, about the single ended supply, how do you use capacitor in this case ?
Old 12th December 2012, 06:38 AM   #12738
Compare the B1
regards Andrew T.
Old 15th December 2012, 03:10 AM   #12739
gootee is offline gootee  United States
Originally Posted by tinitus View Post
I would suggest Pnasonic FR
25V, 3300uf
can size 16x25mm, ESR 14 mohm(0.014)
very impressive 3.8A ripple current
buying 100 of them wouldn't cost much
but to mount and wire them all...
btw, where are the limits regarding lowering ESR and increasing current handling, by paralelling caps ?
(I suppose it takes other considerations than just simple math)
Actually, if we parallel them the best way, then the math gets really simple (because everything gets so peachy that the math basically ceases to be an issue).
I will admit that I have been exploring some ideas abouit paralleling caps. But, even better than that, I found somebody who already knows far more than I do about it!
Anyway, here is a link to the best summary and solution that you're likely to find (this easily :-), about paralleling capacitors for use as reservoir caps in an audio amp power supply (AND as decoupling or "local reservoir" caps at the power output devices):
LM3886 component selection
Yes, you have to go to each of those links. But then you, too, will know...!
I was kind of kidding about the math. "WE" don't have to worry much about it, here. But if an engineer did this at work or for a commercial product, then it would be very important. You will read about it very briefly, if you follow the link and the sublinks, but it involves determining the optimal shape of an array of capacitors connected between two conductive planes, so that the current flowing between some edge and some other edge (of the planes) "spreads out" well-enough to utilize all of the capacitors.
The reason I mentioned that is because you were wondering about "limits". Well, one of the limits, for paralleling capacitors, is how many you can fit where, while still increasing the beneficial effects by enough to matter, and to be worth doing, as the number of caps is increased. And it turns out that certain shapes of arrays of parallel caps are better than others. And definitely certain interconnection methods are better than others. Any limitations will arrive much more quickly if solid conductive planes are not used, I believe. But just read the links. The (MEASURED!) impedance numbers are extremely impressive. (And if we use enough parallel caps, then their individual current-handling ability becomes much less important, too.)
Old 15th December 2012, 04:16 AM   #12740
lhquam is offline lhquam  United States
How about using superconductors for the interconnects?
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright 1999-2017 diyAudio
