F5 power amplifier
F5 power amplifier
Old 15th November 2012, 11:47 AM   #12681
udailey is offline udailey  United States
Passive Aggressive
F5 power amplifier
Originally Posted by tolikas View Post
any ideas how to fight F5 Hum problems? I use 1 torroidal trafo (600w), is it possible for him to be the source of AC line humming? I am 100% sure that audio boards, power supplies, grounds are ok.
Would AC line filter before trafo help?
100% sure is a sure way to miss a problem. Leave it for a day or two then cone inspect again. It's a grounding problem. I'm 99% sure
Get a few long wires and put alligator clips on them. Attach to earth and poke around other grounds while listening. Works for me.
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 15th November 2012, 12:00 PM   #12682
Marra is offline Marra  United Kingdom
F5 power amplifier
Don't signal and speaker ground connect to the pcb's with a single wire then going to power supply ground.Thats how I did mine with cvillers boards and its as quiet as a mouse.
http://www.diyaudio.com/forums/blogs...ck_f5_rev2.jpg
Old 15th November 2012, 12:02 PM   #12683
valvesound is offline valvesound  South Africa
valvesound's Avatar
very good advice! worked for me too.
Old 15th November 2012, 01:14 PM   #12684
tolikas is offline tolikas
tolikas's Avatar
Originally Posted by valvesound View Post
Look at the picture attached. The purple lines indicate the 0V star point. It is very important. connect both supply 0V points to the star point. From the star point all 0V connections run to individual channels. From the star point run wires to RCA inputs 0V (RCA's are isolated from chassis). keep wire lengths for left and right channels equal length. The only ground (earth) connection is indicated by blue. The mains earth is connected to the chassis there. On the power supply I have a 10ohm connecting chassis earth to the 0V point.
If you do exactly this, you will have a dead dead quiet F5 amplifier.
Actually my F5's internals look even better no offence,but leads are much shorter, star ground is at PSU PCB, ground runs only to diode bridges, and to audio PCB's from there...Plus one lead to chassis, via thermistor 4.7ohm.
I have a suspition , that trafo secondaries are catching noice from primary windings...
Old 15th November 2012, 01:18 PM   #12685
tolikas's Avatar
Sounds easy and promissing, will post about results Thanks
Old 15th November 2012, 01:21 PM   #12686
Passive Aggressive
F5 power amplifier
No. Secondaries will only pick up 60hz from primaries or 50hz, which they already have. Supply could pick it up but it gets rectified, then caps and series resistance should filter it. Other chance might be bad solder joint.
Old 15th November 2012, 01:25 PM   #12687
Passive Aggressive
F5 power amplifier
Make sure to use test leads from ground in F5 to preamp as well.
Old 15th November 2012, 02:05 PM   #12688
valvesound's Avatar
Actually my F5's internals look even better no offence,but leads are much shorter, star ground is at PSU PCB, ground runs only to diode bridges, and to audio PCB's from there...Plus one lead to chassis, via thermistor 4.7ohm.windings...
No offence but its not how it looks on the inside it is how it sounds. Sometimes in trying to keep things neat and tidy the best grounding practices are not followed. I did initially wire the PCB's amp and PS according to layout and I did have hum / buzz. Its only when you start pulling things apart that you find the solution.
Old 15th November 2012, 04:30 PM   #12689
AudioSan is offline AudioSan  Norway
do not make a starground on the PSU pcb. thats a dirty ground.
can it be a groundloop you have? if its 2 ch amp with common PSU.
if thats the case. try a short fat cable between the 2 amp's GND.
Old 15th November 2012, 04:52 PM   #12690
flg is offline flg  United States
flg's Avatar
I would like to comment that a typical toroid will pass likely the whole audio band albeit not flat, thru it's primary - core and secondary windings if that's what the line has to offer. What I just read makes it sound like a 50-60Hz bandpass filter which it is far from
Originally Posted by AudioSan View Post
do not make a starground on the PSU pcb. thats a dirty ground. can it be a groundloop you have? if its 2 ch amp with common PSU. if thats the case. try a short fat cable between the 2 amp's GND.
The forever argument? There are high current transients thru the diodes, first caps and back to the xfrmr. One recomended spot for the GND is at the -connection of the second cap(likely still on the Pwr Supply board). The reason is simple, you dont' want all that current going thru the extra wire to the amp circuit board GND having a resistnce that makes your low esr caps have the DSR/ESR of that wire added to the Vcc or Vee... But, the circuit board GND is also a good place IMHO
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
