Old 12th November 2012, 02:31 PM   #12671
Nice to see you got it running!
I would move the IEC input and softstart to the middle of the back panel and the inputs somewhere above or below the respective speaker binding posts.
"You have a hierarchy: a mathematician, a physicist (which is a failed mathematician), and an engineer (which is a failed physicist)." - Andrew Jones
Old 12th November 2012, 08:16 PM   #12672
... and maybe a couple of holes for internal air circulation -
... jh
Old 13th November 2012, 06:29 AM   #12673
valvesound's Avatar
Yes something I'll do next time round. I do not have any interference or hum so not required but something I would do differently in future. Thanks
Old 13th November 2012, 06:40 AM   #12674
Guys, i recently moved overseas, and where my f5 has been built and biased on 230vac, my new home has 220v (at least according to spec, haven't measured actual yet as my stuff is still on its way on a container vessel).
Given the psu is unregulated, what can i expect when i turn the amp on?
TDA1541a-S2 / 6072a / MediaplayerDac -- Michell Gyrodec -- Aikido Preamp -- Pass F5 -- Audio Physic Tempo 2SE -- Yamamura Cabling
Old 13th November 2012, 06:49 AM   #12675
sangram is offline sangram  India
^^Where I live the mains varies from 200 to about 260VAC and the frequency from 44 to 56 depending on the mood of the monkey turning the switches that day.
Never had an issue. I suspect you won't either
Old 13th November 2012, 07:12 AM   #12676
valvesound's Avatar
yes studiostevus, no need to be concerned.
Old 15th November 2012, 07:55 AM   #12677
tolikas's Avatar
any ideas how to fight F5 Hum problems? I use 1 torroidal trafo (600w), is it possible for him to be the source of AC line humming? I am 100% sure that audio boards, power supplies, grounds are ok.
Would AC line filter before trafo help?
Old 15th November 2012, 08:22 AM   #12678
promitheus's Avatar
Hum is probably a problem of bad earthing or multiple earth points.
Do you have any photos of your wiring?
Input, output and power supply earth points?
Old 15th November 2012, 08:24 AM   #12679
valvesound's Avatar
Default F5 grounding
Look at the picture attached. The purple lines indicate the 0V star point. It is very important. connect both supply 0V points to the star point. From the star point all 0V connections run to individual channels. From the star point run wires to RCA inputs 0V (RCA's are isolated from chassis). keep wire lengths for left and right channels equal length. The only ground (earth) connection is indicated by blue. The mains earth is connected to the chassis there. On the power supply I have a 10ohm connecting chassis earth to the 0V point.
If you do exactly this, you will have a dead dead quiet F5 amplifier.
Old 15th November 2012, 08:24 AM   #12680
triode_al's Avatar
Just less overhead. And by the way, the transformer will be cooler (less saturation). The bias will remain (almost) the same. But you will normally never hit the power rail, and the F5 intrinsically has soft-clipping anyway.
DAC TDA1541 S1; MC30-Super --> two stage RIAA; SP-6 clone ; 300B PP: 6N7/ECC82, Metalimphy output.
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright ©1999-2013 diyAudio
