F5 power amplifier
F5 power amplifier
Old 9th November 2012, 08:43 AM   #12651
valvesound is offline valvesound  South Africa
valvesound's Avatar
light is a bit bad...hopefully you can see
Old 9th November 2012, 08:59 AM   #12652
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F5 power amplifier
that's present pic ?
already pull them from the amp ?
whatever - desolder mosfets and jfets , check them with Idss test
check all solder points , use magnifier if needed
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 9th November 2012, 09:13 AM   #12653
valvesound's Avatar
No, that is a pic just before fitting to heatsink.
What is the easiest multimeter test on the fets? Test impedance between G and S for very high impedance (open cct)?
Old 9th November 2012, 09:24 AM   #12654
Zen Mod's Avatar
F5 power amplifier
well , picture of parts still in bags is almost equally useful
except fro measuring dead part - short between pins - DMM alone isn't too much useful for testing them
Old 9th November 2012, 09:33 AM   #12655
valvesound's Avatar
Thanks for the interest to help ZM!
If I pull the fets from the boards and test them to be ok I am going to look for the answer in the bottom of a bottle of whiskey.
Old 9th November 2012, 09:49 AM   #12656
Zen Mod's Avatar
F5 power amplifier
you can't do much funnier thing on end of the week
but - do that with some company , and stay at 0,2L per head
for mosfet testing look at Pa's articles on FW
for Jfets - here it is (0 Rs for Idss)
you can use 9V battery instead of 12V drawn
Old 9th November 2012, 09:51 AM   #12657
fdlsys is offline fdlsys  South Africa
fdlsys's Avatar
Originally Posted by valvesound View Post
Guess the culprits will most likely be the mosfets as they are static sensitive.
W, where did you get your JFets from? I presume you didn't measure them before soldering, hmm? Asking because the world is flooded with fakes...
M
Old 9th November 2012, 10:35 AM   #12658
valvesound's Avatar
Hi Mike!!
I got them from B&M enterprises paid handsomely because I was afraid of the Chinese versions. I believe them to be good originals. But nooo...I did not measure them before installing :-o
I'm sure I must have damaged an output mosfet with static or something...all I can think.
Old 9th November 2012, 10:37 AM   #12659
valvesound's Avatar
NO NO...0.2L is not enough volume to achieve resonance!!!!
Old 9th November 2012, 11:41 AM   #12660
Russellc is offline Russellc  United States
F5 power amplifier
Try barrel strength!
Russellc
Pass B-1 preamp, Pass BA3 preamp, Pass F-5 Amp, Pass F-6 Amp, Pass BA-3 Amp, Pass M-2 amp, Pass Aleph J amp, Pass Pearl 2 Phono pre
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
