#12611 |
you can hard wire the P3 without much problem.
aleph P1.7 pre. F5 power amp. CDpro2(need DAC). Vivaldi8 speakers |
#12612 |
My F5 will be a stock one in first time... Tweaks will come after if necessary.
Transformers will arrive tomorrow, I have ordered two 300VA 2x18V, one for each channel ![]() Damien |
#12613 |
#12614 |
solder the P3 direct to the legs of R1, R2? (10ohm resistors)
#12615 |
#12616 |
Jack, have you tried moving R1 to the other side of R2 as seen in the F5 Turbo manual?
#12617 |
is there a reason for the 47.5K input impedance? vs. 100K as Cviller's schematics?
#12618 |
#12619 |
John,
I see you haven't included the provision for the small value gate stopper resistors (47R & 68R) and filter capacitors on the input jfets, as in your early design with the double sided board? Did you find these additions to be counter productive? Is it possible to line the power resistors up "sideways" to attach the Caddock style (TO220/247 packages) power resistors to a common heatsink thru the centre of the board? And perhaps adding a Cmultiplier/simple zener regulator onto the ends of the board with room for 25mm power supply caps?
... jh |
#12620 |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 10:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 08:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
