Old 22nd June 2008, 10:09 AM   #1251
rubydac is offline rubydac  Hong Kong
Send a message via MSN to rubydac
Default 2A for F5 ?
Could I increase bias from 1.3A to 2A for F5 ?
Because now I had compared with my Aleph J cloned, I loved Aleph J more than F5 because its close to my 2A3 but in my remember I had adjusted bias of F5 from 1.3A to 1.75A ! I loved it !
What's problem if I change bias of F5 to 2A ? (don't tell me it's so hot !!!)
Rubydac
Old 22nd June 2008, 10:18 AM   #1252
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
Default Re: 2A for F5 ?
why not - if you keep mosfets cool enough (Papa's usual test - hand on 'sink)
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 22nd June 2008, 11:02 AM   #1253
Default Balanced version schematic?
I'm not sure if this has been already answered but I've seen a few references to a balanced version of the F5 but don't recall a schematic from Nelson, what the gain would be compared to the srandard version, whether he built one and if so how it sounds in comparison. Just curious.
Old 22nd June 2008, 11:06 AM   #1254
EUVL is offline EUVL  Europe
If you are still using +/-24V power supply, you would be running each MOSFET at 48W. Even if you have a large enough heatsink (say 0.4K/W per channel), your MOSFET junction temperature would rise to almost 100 degC. Unless of course you use water cooling to run the MOSFETs at case temperature of about 30 degC (essentially room temperature in the summer in Hong Kong).
You may ask what's wrong with 100 degC junction temperature.
Nothing, except the realibility of the MOSFETs goes down significantly. So if you are prepared to accept that the MOSFETs wil fail now and then, and you have speaker protection installed, by all means.
Of course you are also changing the "sweet spot" at which the original circuit is set by going to 2A, as the drain resistors (trimpot) of the JFets would have to be increased to increase the bias of the MOSFETs. You may of course also achieve the same by increasing JFet bias instead, by using devices with an Idss of say 10mA and keeping the drain resistors as they are (at around 700 ohm).
Or you may wish to consider using the balanced circuit I published, which runs at 16V 2A per MOSFETs, thus still keeping dissipation per MOSFET at about 32W.
I have only built and listened to my all-Toshiba balanced version, so I cannot comment on how different it may sound to single ended Fairchild. But I believe Nelson has both single ended and balanced versions, so perhaps he might care to say a few words on that.
Patrick
Old 22nd June 2008, 05:04 PM   #1255
The one and only
Nelson Pass's Avatar
Default Re: Balanced version schematic?
Ordinarily the gain would be the same.
Balanced versions would come in various flavors.
The primary advantage of balanced output operation is more power,
since the push-pull nature of the single-ended version already has
a third harmonic character at higher power levels. Assuming that
you want to maximize the power, the first thing you are likely to do
is to double the number of output devices (2 in parallel), although
this is not essential.
Then you consider whether you simply want to "bridge" the
amplifier by taking to F5 channels and operating them across the
load out-of-phase.
Lastly, assuming that you want an input stage which integrates
what would otherwise be two separate independent input stages,
you have a couple of obvious alternatives.
The most obvious is to simply take the 10 ohm resistors to ground
and connect them to each other instead.
The other is to make an X circuit out of it.
Old 22nd June 2008, 05:34 PM   #1256
Variac is offline Variac  United States
diyAudio Editor
Variac's Avatar
oooh!! ahhhh!
Old 22nd June 2008, 06:02 PM   #1257
The one and only
Originally posted by Variac
oooh!! ahhhh!
Doing the time warp again?
Old 22nd June 2008, 06:07 PM   #1258
49 - for the 16th time
c2cthomas's Avatar
oooh!! ahhhh!
Work'n on a Chain Gang?
http://music.yahoo.com/Sam-Cooke/Cha...5102#lyricstop
"You can't always get what you want" K. Richards/M. Jagger *** "Next time I will know some things better" Zen Mod
Old 22nd June 2008, 06:10 PM   #1259
> Then you consider whether you simply want to "bridge" the amplifier by taking to F5 channels and operating them across the load out-of-phase.
> Lastly, assuming that you want an input stage which integrates what would otherwise be two separate independent input stages, you have a couple of obvious alternatives. The most obvious is to simply take the 10 ohm resistors to ground and connect them to each other instead. The other is to make an X circuit out of it.
Referring to Klaus's post earlier regarding these 3 variants :
http://www.diyaudio.com/forums/showt...33#post1538833
" I simulated all three variants, the simple Bridge (the nodes in question grounded), Zinsula (nodes connected directly) and yours (nodes cross-connected only). But I couldn't find any significant change in distortion, both looking at the single-ended outputs (ref'd to GND) and the differential ouput, the third harmonic always dominated THD with its stable value. "
I wonder if you would care to comment on the merits of each of the three ?
Patrick
Old 22nd June 2008, 08:29 PM   #1260
The one and only
Depends partly on the device models. If the N devices and
(separately) the P devices are literally identical which is likely the
case in your simulation, then the even harmonics cancel for similarly
and the odd harmonics are reduced by the proportion of feedback
which can also be made similar.
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
Dennis Hui, Bksabath
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Page generated in 0.18553 seconds (58.61% PHP - 41.39% MySQL) with 11 queries
