F5 power amplifier - Page 1258 - diyAudio
Old 27th August 2012, 09:56 PM   #12571
hello. a had the same problem the F5 interest came to late
well. i can help you with a BOM.
however. what boards are the best for you, depends on your heatsinks. (so you can spread the heat evenly) but the store's boards are wery good. at least for sinks thats max 300mm. over that, or with 2 sinks conected together. a wider space between the fets will be good.
here is a BOM
Old 27th August 2012, 10:12 PM   #12572
juma is offline juma  Germany
juma's Avatar
Hi jeffharr, welcome to forum !
F5 is a simple amp and it won't be a difficult build for a DIYer with some experience. Read carefully Nelson's article and you won't be needing any guidance:
http://firstwatt.com/pdf/prod_f5_man.pdf
Old 27th August 2012, 10:36 PM   #12573
Rush is offline Rush  United States
Originally Posted by jeffharr View Post
Is there someplace where the latest info, BOM and vendors can be found? The idea of culling several thousand posts to try to figure this out is a bit daunting, and I'll bet some of you have nailed this info and made it available easily. I'll order boards (which ones?) from the Store and sure will appreciate getting pointed in the right direction for info for a standard F5 build, BOM, and parts sources.
I sure hope that I'm not asking for too much, and many, MANY thanks for the help!
Jeff
Really you just need to read the F5 manual, then read the F5-Turbo manual (First Watt website).
I built a couple of F5s and decided to leave out the current limiting section. I have the F5c boards and some others. The F5c are great as you can build a F5-Turbo with 2 pairs of outputs per channel (matched) and use a higher volt rail (32 volts) if you want and cascode the input jfets (Nelson said the turbo sounded more relaxed). Or just build a regular F5 with the same boards. Lots of choices from one set of boards. The power supply boards from the store are also good.
Most stuff you can get from Mouser or Digikey. Heat sinks from Heatsinks USA or complete chassis with heatsinks from eBay sellers (soon from the store). There are several DIYAUDIO members selling boards an outputs and various parts. Buzzford, Zhoufang, Jackinnj, Peter Daniel, check the swap meet forum section.
I have some 2SK170BL and 2SJ74BL if you need them. PM me. 2SJ74BL are getting hard to find.
Hope this helps.
Rush
Old 27th August 2012, 10:58 PM   #12574
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
if ordering pcbs from store , then is worth checking Cviller's Blog
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 27th August 2012, 11:23 PM   #12575
agree
http://www.diyaudio.com/forums/blogs...version-2.html
Old 27th August 2012, 11:50 PM   #12576
6L6 is offline 6L6  United States
6L6's Avatar
Although a stereo build, here is a log of a complete construction from start to finish -
An illustrated guide to building an F5
Made with Antek transformer, Peter Daniel boards (Audiosector.com) Hifi2000/Modushop chassis
Of course it depends on your chassis, but making a pair of monoblocks would be very easy using these parts.
Old 1st September 2012, 12:15 PM   #12577
triode_al's Avatar
Default Problem with paralleling outputs
I have been happily working with an F5 and a single MOSFET output for a year (2SK175/2SJ55) and it worked well.
Well, I decided this week to start to quadruple the output, as I had installed four pairs per side on the heatsink already.
I ran into problems
Top output bottom input (the HF oscillations are reflected to the input even!); the oscillations can be seen first on the upgoing sine from bottom.
  1. Instable - there was instability as I increased the bias in the right channel: severe oscillations beyond a point of about 0,8 Amp total in right Ch. Left can get more and I can set the bias there to about 1,5 amp total.
  2. ringing with a capitative load of 100 nF; a bad issue because I have Quad 57 electrostats.
I noted that when I did a sine on 8 ohm with high volume the instability could start to appear (first on the negative rail).
This issue can be heard on the speakers. There is popping sound and distortion as the volume goes up.
The second issue of ringiong I did not have before in my single version F5, but with an input RC (1k2/1 nF=78KHz) the ringing is not triggered and disappears.
What can be the problem? The N/P sets were selected from a large batch; I have 0,47 ohm source resistances.
Probable cause:
I did have an open connection to -Vb (-23V) when I started (ampere meter not connected) and dialed in the positive side this led to a gate voltage of 23 volt on the 2SK175's (they can stand 20 volts Vgs).
The 2SK175's do work though - on the test bench the right channel gives a flat output to >600 kHz without an input filter and it works well up to clipping. At higher volume, the DC shifts. This all at a low bias. In the room, the R channel exhibits clicks and pops (probably as the instability occurs).
Is this the typical behavior of a 'half-dead' MOSFET?
The ringing is of course independent of the half-dead devices, if I am right.
happy with any light that is shed.
SPU --> tube MM/RIAA; Kaneda pre; 300B SE driven by ECC35; Open Baffle PM2A, 2A9
Old 1st September 2012, 01:17 PM   #12578
lhquam is offline lhquam  United States
Does each FET have its own gate stopper resistor? Perhaps you should show the exact schematic and a photo of the layout.
I ran into problems
Attachment 299090
Attachment 299091
Probable cause:
Old 1st September 2012, 01:24 PM   #12579
Or possibly reduce the number of power fet pairs receiving the signal - ie, lift the gate stoppers on 2 of the Fet pairs and see if the input jfets are happier with the load - may not be the answer but quite simple to try, and if not, easy to replace.
There was some mention a long time back about a small Gate/souce cap on the power fets to solve oscillation problems of higher capacitive loads, I think ....
Old 1st September 2012, 02:11 PM   #12580
jackinnj's Avatar
You mean "each JFET" gatestopper -- not absolutely necessary, but it can be done with slight improvement of measurements.
Of course, the gatestopper for the MOSFETs has to be as near the gate as possible.
Using multiple output devices? -- the input stage might be running out of steam due to the paralleled input capacitance of the output devices.
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright 1999-2017 diyAudio
