F5 power amplifier
F5 power amplifier
Old 19th July 2012, 04:24 PM   #12471
Rush is offline Rush  United States
Originally Posted by jackinnj View Post
Shoulda said -- the TDH+N% is well below 0.01%
2SK170 in GR and BL are generally available which is better than the 2n5457 (suddenly in short supply) -- and it may make sense to use 3x matched 2n5460.
Are you suggesting using 2SK170 GR or BL with a pair or 3 matched 2N5460? I assume you want to equal the idss of the 2SK170 with what ever number of 2N5460 it takes?
Rush
Old 19th July 2012, 04:33 PM   #12472
doolav is offline doolav  United Kingdom
Hi, it likely has been discussed here, but searching through about a half of this thread I still cannot find it, so can anybody advise/point to: what has to be changed on cviller's boards (v.2 - not the current one rev.2) in order to build F5 Rev.1?
Old 19th July 2012, 04:47 PM   #12473
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F5 power amplifier
Cviller's Blog
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 19th July 2012, 05:00 PM   #12474
Marra is offline Marra  United Kingdom
F5 power amplifier
Here's the link
http://www.diyaudio.com/forums/blogs...version-2.html
Old 19th July 2012, 05:22 PM   #12475
thanks, will try.
Old 19th July 2012, 09:22 PM   #12476
jackinnj is offline jackinnj  United States
jackinnj's Avatar
F5 power amplifier
Rush
I substituted one 2SK170GR with Idss of 6.1mA, and the THD was equal to the paired 2N5457. Interesting, however, the 2nd harmonic was a bit higher, but the 3rd was lower and the 4th way down in the weeds.
Old 19th July 2012, 10:05 PM   #12477
Russellc is offline Russellc  United States
F5 power amplifier
shouldnt hurt, should it? I like a little second harmonic...
Russellc
Pass B-1 preamp, Pass BA3 preamp, Pass F-5 Amp, Pass F-6 Amp, Pass BA-3 Amp, Pass M-2 amp, Pass Aleph J amp, Pass Pearl 2 Phono pre
Old 19th July 2012, 10:09 PM   #12478
jackinnj's Avatar
F5 power amplifier
Some more numbers -- using a matched J74GR/K170GR the THD% was 0.0018% 1W, 1kHz. With the 2N5460/2N5457 the best that I could do was 0.0029% -- either number is very respectable. The noise of the J74/K170 seemed to be -135dBV just as in the article while the 5460/5457 was -128dBV.
Old 20th July 2012, 10:43 PM   #12479
alazira is offline alazira  United States
alazira's Avatar
Originally Posted by noSmoking View Post
My fets are on the way,,,,
I have a bunch of 170's in the gr region and all about 10 sj 74 are BL,Ive been stacking the 170 to a close match,I read that the P really needs to be about a ma or two more than the n do you know ?
I believe you are referring to EUVL's source degeneration matching trick.
http://www.diyaudio.com/forums/attac...t-variants.pdf
Although I think it would mostly be useful with complementary output mosfets like the Toshiba 2SJ201/2SK1530.
Old 20th July 2012, 11:11 PM   #12480
jackinnj's Avatar
F5 power amplifier
This is what P3 in the F5-R1 does.
I set up the amplifier bias @1.3A, and output of 2.83V in to 8R and then let the FFT run while adjusting P3. Even with a 25 turn trimpot you find that only a small fraction of a turn will knock the 2nd harmonic down by several dB. As I said previously, be patient, let the beast warm up for a while before making the adjustment --
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
