F5 power amplifier
F5 power amplifier
Old 31st May 2012, 09:36 PM   #12431
labjr is offline labjr  United States
Probably best for a newbie to build the original circuit first. It's the simple and easy to get running, and you don't need matched outputs.
If you like that, then experiment with dual outputs etc.
Old 1st June 2012, 07:13 PM   #12432
mfrimu is offline mfrimu
Default F5 p3 adjustment
Hello,
Thanks for the advice, I will start with a standard rev1 F5. In regards to the P3 adjustment, I have spend 2 hrs searching for a solution and can't find the answer.
Would a USB scope with FFT be adequate for P3 adjustment?
I was thinking about DSO-2250 USB Scope or the VT DSO-2810F. In that case the sound card would be the signal generator. Is that ok? (i'd imagine the FFT functions compares input with output to generate THD graphs?)
Otherwise what is a acceptable setup for this? I'd like to avoid buying an expensive sound card, unless necessary.
Thanks,
Old 1st June 2012, 09:15 PM   #12433
lhquam is offline lhquam  United States
Originally Posted by mfrimu View Post
Hello,
Thanks,
This sound card is not expensive and work great for THD measurement:
http://www.amazon.com/M-Audio-US4175.../dp/B00064ABSG
Old 1st June 2012, 09:32 PM   #12434
Amazon.com: M-Audio US41750 Audiophile 192 Hi-def Aud Card: Musical Instruments
Looks like a good deal indeed! What about the recommended software?
I found this thread: http://www.diyaudio.com/forums/softw...ing-thd-n.html
ARTA does not look like the screen shots i see on this thread...
Thanks.
Old 1st June 2012, 09:41 PM   #12435
Thanks.
This Windows software works well for me. I use it on Linux using Wine.
Visual Analyser 2011 XE
Old 1st June 2012, 10:10 PM   #12436
Rush is offline Rush  United States
Is there anything like this for us Apple user's? Mac Mini or Macbook Pro?
Old 1st June 2012, 11:13 PM   #12437
See MacOSX - The Official Wine Wiki
Old 2nd June 2012, 09:08 PM   #12438
Does one need a sort of buffer protection to connect the amp output to the sound card line-in?
Old 3rd June 2012, 12:21 AM   #12439
regal is offline regal  United States
Yes The sound card will only accept about 1Vrms in, which doesn't give you a very good picture.
Cheap easy buffer is an O2 (see the headphone section) set to no gain. It certainly isn't as good as pmillets interface but it probably introduces less noise/distortion.
Old 3rd June 2012, 01:41 PM   #12440
6L6 is offline 6L6  United States
6L6's Avatar
F5 power amplifier
Did anybody notice that this thread has now more than
2 Million Views!!!
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
