#12381 | |
diy newbie
you should really read up some about the topic ![]() btw the plug is called schuco...
" If you're going throu hell, keep going" |
#12382 |
Could someone tell me what the circuit's max bias amperage is for an F5? I know this is limited by the size of your heat sinks but I would like to know what it's limit is if for example you had the worlds largest and best heat sinks.
*edit* assuming irfp240/9240 devices |
#12384 |
Is that 50watts peak?
#12385 |
nope
quiescent
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#12386 | |
there is also a 1 phase. thats normaly used on caravans and such.
aleph P1.7 pre. F5 power amp. CDpro2(need DAC). Vivaldi8 speakers |
#12387 | |
I have been running pairs of FQP19N20 and FQA12P20 at 32 V 2.6 A since last August on 300 X 400 X 86 sinks (190 W) soon I am going to do balanced on same sinks and may need litle fans to help a bit. And Papa uses Mica and goop with big washer so there may be same head room if one uses Kerafoll and prety uge clamp bar and massive screws
#12388 |
Banned
Bksabath wins todays FAB award
#12389 |
wakoo Serb
#12390 | |
diy newbie
regards
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 10:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 08:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
