F5 power amplifier
F5 power amplifier
Old 14th May 2012, 04:54 PM   #12321
6L6 is offline 6L6  United States
6L6's Avatar
F5 power amplifier
Does removing the protection circuit change or affect the rest of the circuit at all? Will I need to re-bias?
It's not that replacing the devices is difficult, just that getting new ones is a headache... as I have no replacements on hand.
Old 14th May 2012, 05:14 PM   #12322
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F5 power amplifier
nope
they're not in function while amp is idling
that's critical only when you're doing that for money , as day job
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 14th May 2012, 05:15 PM   #12323
luvdunhill is offline luvdunhill  United States
luvdunhill's Avatar
That fix doesn't make any sense. So what if the circuit ground is connected to the chassis? Something else is going on here.
Old 14th May 2012, 05:22 PM   #12324
Zen Mod's Avatar
F5 power amplifier
I'm sure that something else was "chassised" , not tone gnd
Old 14th May 2012, 05:24 PM   #12325
6L6's Avatar
F5 power amplifier
I have thought that as well, but don't know where to start determining the problem...
Old 14th May 2012, 11:22 PM   #12326
daviddsailor is offline daviddsailor  Australia
Is the copper surrounding the PCB mounting holes actually going anywhere? From my faint memory of the boards I have used I thought there was just a doughnut of copper surrounding the holes and it didn't go anywhere (don't hold me to that). One F5 I built went funny in one channel and on the CRO with a sinewave in, one half of the sinewave was more compressed (rounded off) that the other. This gave a subtle distortion to the sound. That turned out to be one faulty FET in the input section. I assume that your rail voltages are both the same and and DC on the output is less that about 50mV.
Old 14th May 2012, 11:36 PM   #12327
6L6's Avatar
F5 power amplifier
They are the newest cviller boards, and no, the copper in the mount holes isn't supposed to be connected to anything!
Yes, the rails are both very close to 23.8 volts and the offset is almost zero.
Old 14th May 2012, 11:57 PM   #12328
I have never used those boards. Just JIM's and one other similar to JIM's. I assume you don't have access to an audio signal generator and a CRO so that doesn't make it any easier. I suppose all you can do is check all the components again, preferably out of circuit and maybe substitute some semiconductors from the board that is working. Regards.
Old 15th May 2012, 01:07 AM   #12329
Rush is offline Rush  United States
Ok, here is a question for those if you much smarter than I -- (which is most everybody...)
Now that both channels are completed and the amp measures and biases normally, the channel that was shorted sounds a bit fuzzy. (it's subtle, but very much there.)
I am not smarter than anyone here, I can proof how dumb I am by all the dumb things I've done and had to fix.
The fuzzy sound, sounds like a bad solder joint, cold solder joint and it could be anywhere, even the ground wires.
Check all the solder joints and resolder any or all that have not bleed through to the other side of the board. Don't over heat though.
It could be a high frequency oscillation. Try adding (clip on) a small cap (100 pF) across feedback resistors or gate to output. To see if the fuzzy goes away. If it does, look for a reason why that channel is different than the other one. For that matter, do that anyway, look to see how it is different than the good one.
Keep looking for something and you will find something. It is frustrating until you find it, then very satisfying. You will feel like you know something about layout, soldering, oscillations, or whatever.
By the way, all the board help keeps you looking for the problem. In the old days, I just set the project aside and never figured it out, feeling lost with no one to ask. Hooray for these forums, well the internet in general.
Rush
Old 15th May 2012, 03:21 AM   #12330
hartze11 is offline hartze11  United States
hartze11's Avatar
I'm looking at my unassembled cviller v2.0 boards, and while the mounting holes are plated, they don't connect to anything else on the pcb...
Just curious, did you clean all the flux off?
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
