F5 power amplifier
F5 power amplifier
Old 28th April 2012, 05:56 PM   #12311
fdlsys is offline fdlsys  South Africa
fdlsys's Avatar
Originally Posted by Charly1 View Post
Thanks Yes thats why I have two transformer with each center tap winding. My problem is how can I use this Jims board with two seperate bridges.
What does it matter who made the PCBs? They all have the (+)-(0)-(-).
Old 28th April 2012, 07:54 PM   #12312
6L6 is online now 6L6  United States
6L6's Avatar
F5 power amplifier
On the output, yes. But the input to the board is different depending on which particular board.
It depends on which Jims board you have and your transformers. Can you give more detail and/or post some photos?
Old 28th April 2012, 11:37 PM   #12313
Charly1 is offline Charly1  Australia
Many thanks for the answer.. I used the big one with 8 caps and 8 resistors. Its seems he design it for one channel. I used 2 boards on my amp now fine..thanks again
Old 2nd May 2012, 06:59 PM   #12314
studiostevus is offline studiostevus  Netherlands
Just wanted to report back: the only fault was the wrongly supplied feedback resistor.
The amp is running now!! Still burning in the caps, but it sounds sooo smooth in the highs and mids!
Old 3rd May 2012, 11:44 AM   #12315
formula 22 is offline formula 22  El Salvador
formula 22's Avatar
What a miracle 1232 page directly!??
Allow phonetic typing.
Cheers!
Kakvo cudo 1234 sranice!!????
What a miracle 1234 page directly!??
Cheers!
Old 14th May 2012, 04:22 PM   #12316
6L6's Avatar
F5 power amplifier
Ok, here is a question for those if you much smarter than I -- (which is most everybody...)
During the assembly of my new F5, (one channel of) the amp PCB was grounded via the mounting screws, and it took me a bit of time with it powered up to figure out the problem.
Throughout this time the PSU was powered with a 100w light bulb on the mains lead (I.E., a mains lead tester). (Yes, it was fairly bright then...)
Once the metal mounting screws were replaced with nylon, there was no more problem and things were completely normal. Nothing seems burnt, scorched and/or overheated.
Now that both channels are completed and the amp measures and biases normally, the channel that was shorted sounds a bit fuzzy. (it's subtle, but very much there.)
My question is this - Which of the transistors (inputs, outputs, limiters) would most likely have been hurt by this episode? Obviously I could replace the whole set, but if I don't have to go that far, I would rather just replace the suspect ones.
Also, is there any easy test to see if the devices are damaged? (I probably don't have the equipment necessary, as the amp is operative, just a bit wonky...)
Old 14th May 2012, 04:33 PM   #12317
Pemo is offline Pemo  Mexico
Pemo's Avatar
I can assure you, that if you are into DIY anything, you are one of the most intelligent in the world.
Old 14th May 2012, 04:35 PM   #12318
flg is offline flg  United States
flg's Avatar
You might use your ohm meter to ohm out conections on the top half vs the bottom 1/2 (swithcing red to black where appropriate) and look for significant differences???
So waht was connected wrong during the episode? Which screw was it?
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Old 14th May 2012, 04:41 PM   #12319
6L6's Avatar
F5 power amplifier
I'm not sure of the suspect screw, (Nothing was obvious) I just replaced them all with nylon and went merrily on my way -- fat, dumb, and happy...
Old 14th May 2012, 04:50 PM   #12320
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F5 power amplifier
desolder 2 bjts from protection first , and hear is there difference .
besides these , there are just 4 important transistors
you can start from small ones , changing one by one and listening is there positive change
in fact , that demands less energy than typin' one post and reading 3 replies
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
