F5 power amplifier
F5 power amplifier
Old 24th April 2012, 08:49 PM   #12301
Itsmee is offline Itsmee  England
Itsmee's Avatar
To prevent smoking the outputs, lift up one leg of R13 & R14, power up and feed a signal in, scope up the drains of the JFETS, do they work ok?
Old 24th April 2012, 09:23 PM   #12302
studiostevus is offline studiostevus  Netherlands
I have disconnected one leg of R13 and R14, and power up with a signal (1KHz sine). The signal comes from the soundcard (no preamp).
I see:
- Voltage across R12 = 1.3VDC
- Voltage at output = 4.5VDC and rising
- I have measured the signal at R13 and R14 with scope (connected to drain of the JFETS). The signal at R14 has lower amplitude than at R13 (about 1/3 in amplitude). The shape of the signals is a bit of a skewed sine.
Interestingly, when I switch off the power supply to the amp, the signal at the drains of the two JFETS become both a very nice and smooth sine (equal on both JFETS) for some time, until voltage drops below about +/-5V.
Old 24th April 2012, 10:07 PM   #12303
I guess the difference in amplitude is due to different settings for p1 and p2...
TDA1541a-S2 / 6072a / MediaplayerDac -- Michell Gyrodec -- Aikido Preamp -- Pass F5 -- Audio Physic Tempo 2SE -- Yamamura Cabling
Old 25th April 2012, 09:55 AM   #12304
I found an incorrectly supplied resistor: R6 was 3K9 and should be 100R
Can somebody please give me the correct values for measuring across R8/R5/R7/R6 in circuit? I get on one channel 40R (bad) and on the other 12R (the good channel!)
Old 25th April 2012, 12:36 PM   #12305
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F5 power amplifier
you're chasing your own tail
do what I already told you
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 25th April 2012, 05:42 PM   #12306
dungdochi1978 is offline dungdochi1978  Viet Nam
GND of output move to GND of board.
check all part if ok-->reduce value of R feedback down to lower 600ohm (50ohm may be more..and increase when it ok).original circuit is simple theory (read again working Jfet,mosfet..)
Q3 open feedback control by Q1 ( Q4,Q2 is the same ).
Old 28th April 2012, 07:18 AM   #12307
Charly1 is offline Charly1  Australia
Default Red board for stereo
Hi Gents any body used this board for two transformer 2 bridge configuration? I think we need to cut the center to seperet them>
Old 28th April 2012, 09:08 AM   #12308
R.I.P.
You need a dual secondary to build a dual rectifier dual polarity PSU.
regards Andrew T.
Old 28th April 2012, 09:17 AM   #12309
Thanks Yes thats why I have two transformer with each center tap winding. My problem is how can I use this Jims board with two seperate bridges.
Old 28th April 2012, 10:08 AM   #12310
R.I.P.
Ask Jims
regards Andrew T.
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
