#12271 |
Im using the ebay boards from jims audio. the resistors are actualy just over an inch from the Fets
![]() No. sounds like a nice idea tho! Last edited by Rixsta; 23rd April 2012 at 08:33 PM. |
#12272 | |
#12273 |
desolder both jfets an mosfets and check them
simple as that and fastest
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#12274 | |
I put down both trimmers P1 and P2 of the bad channel back to 0Ohm --> tested again with my last fuse and normal IEC cord --> Tataa... nice 47V supply power to the channel, of course 0 bias, and a little DC offset... Then.. I though.. what the heck.. and I started adjusting the P1 and P2 trimmers... and guess what: I could just trim them to 0VDC offset and 0.5xxV bias... like nothing happened... All of course on the bench with no speakers or preamp attached. |
#12275 |
Perhaps the speakers are the problem? Do they work with other amplifier? (Just trying to eliminate unknowns)
#12276 |
Uuhm yes!
-------- TDA1541a-S2 / 6072a / MediaplayerDac -- Michell Gyrodec -- Aikido Preamp -- Pass F5 -- Audio Physic Tempo 2SE -- Yamamura Cabling |
#12277 |
I have two 4ohm 20w resistors here... Would it be a good idea to test with those, or are there steps I need to take first?
#12278 |
I guess the question that i have really is:
1. I can re-bias the amp, does that mean that nothing was damaged? 2. It seems its working with no load. What could have caused smoke with load? Too high bias?
#12279 |
1. if you can rebias its very likely the amp to have survived the bad event (besides possible heat damage most likely on resistors without them being completely faulty)
2.what smoked?? Any damage visible? As long as the heatsinks didn't go beyond 60 degrees Celcius the bias should not have been too high. |
#12280 |
1. That's hopeful...There is no visible evidence of damage. 2. I had the lid on, so unfortunately i couldnt see what smoked. I had already run the amp for 2-3 hours to warm up and bias. Then i unplugged it, carried it to the living room and hooked up the speakers and equipment. It had probably 10mins to cool down. Then i fired it up, started the preamp, and smoke appeared.... Probably within 10 or so seconds. Then i quickly shut it down... The heatsinks certainly were not 60 degrees
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 10:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 08:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
