F5 power amplifier
F5 power amplifier
Old 18th April 2012, 12:43 PM   #12211
jackinnj is offline jackinnj  United States
jackinnj's Avatar
F5 power amplifier
you can always use an LM317 / LM337 set up as 400mA current limiters for the initial testing -- once you get the amp to this level it's easy to remove the current limiters and keep climbing up to the bias you want. Make sure to heat sink the regulators.
It's always helpful to make a note of which direction of the trimpot moves the bias current up or down.
And with the F5, patience in adjusting the bias is its own reward.
Old 18th April 2012, 02:07 PM   #12212
dungdochi1978 is offline dungdochi1978  Viet Nam
better check one by one Jfet,Mosfet by using matching circuit to confirm material work in order.
Old 18th April 2012, 02:15 PM   #12213
studiostevus is offline studiostevus  Netherlands
Speaking of matching: I ordered some matching transistors from another forum member.
I received:
2x IRFP9240 - 4,034
2x IRFP240 - 4,111
I am surprised to see this, I would think to minimize distortion you want to match N-channel with P-channel, no??
Old 18th April 2012, 02:58 PM   #12214
also can check working V,I of them when you change with each value voltage of matchinh circuit.
Old 18th April 2012, 03:17 PM   #12215
Default fully check
I received:
2x IRFP9240 - 4,034
2x IRFP240 - 4,111
check 02 jfet Ids --will decide Vgs of IRF
check 02 IRF Ids bothside when Vgs changing also temp changing ..
and IRFP9240 seem too high Amp no need can change by other,because circuit only run whith 2,6A ..cut off by protection circuit.
Old 18th April 2012, 03:53 PM   #12216
Bksabath is offline Bksabath  United Kingdom
Banned
Just in case you missed this.
Mighty Zen F5 bias setting doc
Old 18th April 2012, 04:19 PM   #12217
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
surprised to see this, match N-channel with P-channel
IRFP240 and IRFP9240 are not complementary devices.
These were likely matched at a drain current of ~250mA, at a little above 1A they'd have close to identical Vgs.
The "matched" part refers to Vgs difference between the two IRFP240, or between an IRFP9240 and the second one.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 19th April 2012, 01:22 AM   #12218
Default check all
Because you want to make high quality amp.I suggess to you need check all part for build up in your amp ( resistance, jfet,mosfet,power.) with changing of V,I,Temp (should be fix mosfet on heatsink actually testing for try with some degree of temp).everything can happend.
Old 19th April 2012, 10:36 AM   #12219
Djenka018 is offline Djenka018  Jamaica
Originally Posted by wengtech View Post
primary 0-220-250
secondary 0-36-55 0-36-55
addition 18-0-18
shown on my toroidal transformer.
You could use 36V and 55V outputs and get 19V, providing there is sufficient current from them.
That is just these two (pairs of) wires, nothing else.
Old 19th April 2012, 10:36 AM   #12220
Thanks for all your advice.
What still confuses me is the bulb tester. I know it functions as a current limiter. But what exactly am i testing with it?
And what should i be looking at when i power up with the tester (aside from smoke, fire & explosions) ?
TDA1541a-S2 / 6072a / MediaplayerDac -- Michell Gyrodec -- Aikido Preamp -- Pass F5 -- Audio Physic Tempo 2SE -- Yamamura Cabling
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
