F5 power amplifier
F5 power amplifier
Old 16th April 2012, 10:38 AM   #12201
formula 22 is offline formula 22  El Salvador
formula 22's Avatar
What preamp for F5?
thank you!
Old 16th April 2012, 10:46 AM   #12202
R.I.P.
You may not need a Pre-amplifier.
A volume control between the Source and the Power Amplifier may be all you will need.
regards Andrew T.
Old 16th April 2012, 11:00 AM   #12203
formula 22's Avatar
Hi AndrewT!
I want to put the entrance to a simple tube line stage (Av<15dB) to bias amplifier F5 with a tube/valve-like sound.
Here for example with the tube pcc88.
thank you and cheers!
Old 16th April 2012, 12:36 PM   #12204
fdlsys is offline fdlsys  South Africa
fdlsys's Avatar
Originally Posted by formula 22 View Post
...F5 with a tube/valve-like sound.
If you haven't built the F5 (or listened to it) yet, then rather do that first. You might be surprised with what (to my ears!) sounds valve-ish, by design
I believe that non fully complementary nature of J74/K170 and IRFP devices can be "blamed" for that.
My 0.02 of local currency
Old 16th April 2012, 03:58 PM   #12205
dungdochi1978 is offline dungdochi1978  Viet Nam
Default add 02x0.22R at out point both IRFP
Originally Posted by Nelson Pass View Post
Very likely.
Dear Nelson Pass!
did you have idea to me ? Can I put more 2x0.22R-5w to separate circuit at OUT D gate of Q3,Q4 (keep R5,R7,R8,R6 like original circuit )and then betweent 2x0.22R will connect to speaker ???
is it will OK ????
Old 18th April 2012, 07:43 AM   #12206
studiostevus is offline studiostevus  Netherlands
Startup procedures for F5.
I have almost finished my F5 build, and already tested the PSU. I get a nice +-24.0VDC on both rails, so that is looking good. Now I would like to fully test the F5.
I don't have a variac, or a set of spare speakers I can use for testing. I can of course use the lightbulb wire, but isn't that only used for testing the PSU? I have a bunch of DMM's and a scope at hand.
The big question is: when can I be sure that I am ready to connect them to my speakers and nothing blows up? Is 0 VDC on the outputs all I need to worry about?
EDIT: To be sure, I don't mean biasing... I have seen very good descriptions of the process on the forum. I am just looking for some checklist that I need to run before hooking it up to my main speakers...
Old 18th April 2012, 08:00 AM   #12207
noSmoking is offline noSmoking  United States
noSmoking's Avatar
F5 power amplifier
Hi studiostevus,
I bought a 8 ohm load resistor,just for that It's rated for 100 watts ,so you can connect it instead of your speakers and watch the output on your scope,It is possible to use a small fuse inline with the speakers so it blows and not your speaker coils,I connect a freq. gen at 1000hz and run up the input voltage slowly and watch the output on the scope,you can also meter your rails DC and lower the fuse in your power supply just to test,check bias often until it gets to operating temp ,I hope this help ,a small set of test speakers can be obtained cheaply at yard sales ,radio shack or parts express,,,,,,Good luck
Old 18th April 2012, 09:09 AM   #12208
dear ! about blows up speaker : you can check I1,I2 must be the same value at bothside of amp.
Old 18th April 2012, 09:51 AM   #12209
R.I.P.
the bulb tester can and should be used to power up every change or modification to a mains powered project.
The bulb tester cannot be used to bias up the output stage. But by then all the modifications and additions will have been completed and tested and proved to be correct.
If you make a further modification after you have biased up your F5 then I strongly suggest you reduce bias back to zero and power up via the bulb tester so that you are proving to yourself that the modification has not turned a perfectly good F5 into a bomb. Then rebias.
regards Andrew T.
Old 18th April 2012, 11:08 AM   #12210
Ok, so the procedure would be:
1. Setting all trimmers to 0Ohms - proceed to #2
2. Power up with bulb tester - anything to measure at this stage?
3. Power up with normal wire and proceed with #4
4. Biasing procedures - No load - If everything seems ok and stable, proceed to #5.
5. Test with 8Ohm resistor or test speakers and scope - measure DC offset and bias over longer period. If everything is stable, proceed to #6
6. Declare the amp safe and move over to main speakers
Correct?
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
