Old 16th June 2008, 03:00 AM   #1211
udailey is offline udailey  United States
Passive Aggressive
I had no intentions of sealing it entirely. I wanted an inverted graduated cylinder at the top. That way filling it is easy and the steam has an escape. Not going to do it anymore, but I was thinking how I could use the thermistors to trigger a pump to move water from one tank to another whenever the temp increased past 55C. But thats a lot of water to keep it at 55 without a fresh water supply and a drain.
Uriah
Old 16th June 2008, 03:35 AM   #1212
Passive Aggressive
Now that I think about it some more, it would take a really long time for 100 watts, for example, to boil water. If I used a one gallon container it would take 8092 BTUs (2371 WattHours) to get it to boil but thats not even considering heat loss of the water. I think I will keep an eye out for an aluminum container. See, I could vary the amount of water in it to keep the transistors at a steady temp. There has to be a happy medium somewhere.
Uriah
Old 16th June 2008, 02:10 PM   #1213
Assuming your boards will sit underneath the water tank, I'd be very curious to see how you adjust the amp after it's warmed up ;-)
Will it require a scuba mask and snorkel maybe?
I say do it just so you can take pictures of it to show your grandchildren.
Old 16th June 2008, 02:30 PM   #1214
jackinnj's Avatar
A number of sources (some apocryphal) indicate that the expectation of device failure doubles for every 10 degree C rise in temperature. I saw this quoted in an SMPS textbook a few years back. Other sources say that the adage is somewhat misleading.
Old 16th June 2008, 07:11 PM   #1215
Passive Aggressive
Twitchie,
Assuming I do this it does not seem that I will need an aquarium sized tank I was thinking side mounted a few inches from the bottom but closer to bottom than not since thats where the colder water is.
Jack,
I saw that last night to... the 10 degree thing. In this case it was in reference to a CPU which has 90nm traces so heat REALLY matters in that case. It might be the same here to.
Uriah
aside:
Finished my Audio Nirvana 12" Bass Reflex enclosures a few minutes ago. Listening and enjoying right now. They really are nice and a big improvement over my Floor Standing Fonkens. Obviously bass is much better. Imaging is better. They have had no break in period yet. The voices are not as "forward" as with the Fostex based Fonkens but then again I wasnt sure I liked the forwardness of the Fostex when I first started listening so I guess I have to give it a week or so before I decide which I like better in that aspect. Piano and acoustic guitar is fantastic as it is in the Fonkens. Better than anything I have hooked up to my amps so far
Old 18th June 2008, 04:05 PM   #1216
EUVL is offline EUVL  Europe
The WMF file attached is the balanced circuit as built, using 4x Toshiba MOSFETs :
http://www.diyaudio.com/forums/showt...35#post1538835
One way to see full details is to import the wmf file into Word or Powerpoint.
Patrick
Disclaimer :
Not checked or approved by the original creator of the circuit.
Build at own risk.
Old 18th June 2008, 08:15 PM   #1217
juma is offline juma  Serbia
juma's Avatar
Hi Patrick, can you please post a schematics in higher resolution - it's not clear where the connections are (cross point in JFETs source resistors) and component values are unvisible ?
Old 18th June 2008, 08:31 PM   #1218
Magura is offline Magura  Denmark
Magura's Avatar
This is not far from what I'd consider a fact. In my experience upping the temperature to the specified max. (current VS. temp.) makes the thingie go south within roughly 1000hrs.
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 19th June 2008, 04:55 AM   #1219
It is a Windows Metafile and not JPEG.
The resolution is only poor if you open it with a photo editor sort of program.
What you could do is save it first. Open a new Word document (A3 Landscape), "insert graphics from file", then you will see all details in the highest resolution you might ever need.
Patrick
Old 19th June 2008, 10:37 AM   #1220
Patrick,
Can you please post a pcb(pdf) or gerber?
Mike
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
Dennis Hui, Bksabath
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Page generated in 0.16650 seconds (63.60% PHP - 36.40% MySQL) with 11 queries
