Old 10th April 2012, 09:49 AM   #12181
the F5x operates on +-16Vdc
Old 10th April 2012, 10:08 AM   #12182
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by promitheus View Post
smallest Voltage without loosing quality?
The JFETs require 6 to 7 volts minimum at the drain, so at least 10-11 Volt rails.
Not so much,.......if it says "ZM" in the corner.
Old 10th April 2012, 09:27 PM   #12183
formula 22's Avatar
Hi all!
uh ... how long issue?!
Old 11th April 2012, 09:13 AM   #12184
promitheus's Avatar
thanks for the information.
I was thinking of making a smaller amplifier to test and for low volume music.
The normal F5 can give 50W peaks and is 25W normal power class A and needs a 300VA transformer.
A 2x12V 100-150VA transformer should give 16V rails.
This should give 9W normal power with 18W peak capability.
I think the correct bias would be 0,75A.
Heat dissipation per channel is 24Watts so the needed heatsink would be 0,84°C/W for 20°C difference.
I hope my thoughts are correct.
Old 11th April 2012, 10:33 AM   #12185
Are you the same "Promitheus" that has the "promitheus diy" webpage ("mitglied")?
... jh
Old 11th April 2012, 11:01 AM   #12186
promitheus's Avatar
yes I am but I didn´t know that the website still worked.
I haven´t changed it for like a long time.
Old 11th April 2012, 11:22 AM   #12187
Not a half bad idea actually, for 12W dissipation each, one could even use the TO-220 version of the 19N20C/12P20, an FQP pair does ~€2.25 at DK.
Old 11th April 2012, 12:39 PM   #12188
Ah, well how about that!
I remember finding your article about "tuning transformers" some years ago and have been using the technique ever since with remarkable results, and I wanted to thank you for that "little gem" - thank you.
Pity the website is plagued by that irritataing advertising.
... jh
Old 11th April 2012, 05:55 PM   #12189
Rixsta is online now Rixsta  United Kingdom
Send a message via Skype™ to Rixsta
Sites great! is worth updating!!!
Old 12th April 2012, 03:34 PM   #12190
Default Drifting bias
I am having a problem on one of the channels. This was working fine for over a year when all of a sudden one channel developed this problem. I changed the adjustment pots based on suggestion from this forum, and it worked for a few days of extended testing and listening. But now it's doing it again. The bias voltage on the output resistors dropped from .575 to about .400 at first but now it is all over the place. The other channel is rock-steady.
Do you think the thermistors themselves could be a problem? I know, I know. I could change them and see. But unfortunately, due to the beauty of my chassis layout, I have to take out the power supply and the big caps out first to get at the amp board. So iterative troubleshooting is a bit of a pain. Some pointers would be helpful.
UV
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright ©1999-2013 diyAudio
