F5 power amplifier F5 power amplifier - Page 1212 - diyAudio
F5 power amplifier
F5 power amplifier
Old 30th March 2012, 06:57 PM   #12111
udailey is offline udailey  United States
F5 power amplifier
"I use these for vents"
GENIUS! Love it
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 1st April 2012, 12:40 PM   #12112
Pboden is offline Pboden  Norway
Default To small transformer....?
I have a 500va/18vac toroid transformer from Antek that is supplying three F5 channels and I suspect that the transformer is too small. The transformer makes a lot of humming when its turned on.
Iam thinking of getting new ones, but are not sure what would the minimum VA for my configuration. I was thinking of a Antek AN-8420- a 800VA.
Any comments or other suggestion?
Old 1st April 2012, 01:26 PM   #12113
oiphy is offline oiphy  Norway
diy newbie
oiphy's Avatar
F5 power amplifier
you prolly got dc on your net. this will cause the torroid to make noise.
" If you're going throu hell, keep going"
Old 1st April 2012, 01:29 PM   #12114
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F5 power amplifier
less hum with 3-rd channel disconnected from PSU?
be sure that you don't have DC on mains line
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 1st April 2012, 01:53 PM   #12115
500VA 18+18Vac transformer has a maximum continuous AC current rating of 13.9Aac
When feeding a capacitor input filter the maximum continuous DC current rating becomes ~7Adc
Three channels of F5 draw 3.9Adc (3*1.3A of bias) that is ~56% of maximum rating.
I would expect the transformer to be OK for temperature.
It seems likely the transformer is showing symptoms of saturation due to the DC effect of distorted supply waveform.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 1st April 2012, 01:55 PM   #12116
Rush is offline Rush  United States
See Andrews answer above. He is right, as usual.
Rush
Old 1st April 2012, 02:02 PM   #12117
albertNL is offline albertNL
F5 power amplifier
Default Caddock MP915 R5/R6 heatsink requirement
Apologies for my ignorance, but I have a question about R11 and R12.
I am building an F5 using standard diy-audio store boards, 24V rails, tech-diy parts kit plus optional Caddock MP915 and MP930 resistor kit (also tech-diy).
I understand that R1 and R2 (Caddock MP915 10R) will not require heatsinks.
I also understand that R5 and R6 (Caddock MP930 50R) will dissipate up to 5.5W (post 11134) and hence require sufficient heatsinking. I asked about placing on the main heatsink and extending the leads and Nelson replied that is OK (post 11128).
I considered placing R11 and R12 on the main heatsink as well, but am wondering if a small heatsink would also be an option. I am not sure how much these resitors will dissipate. I know that the schematic shows a 0.6V drop, so they would see a current of (I = V/R = 0.6 / 0.5 =) 1.2A (surprise, surprise, the bias current). What I do not know (shows the level of understanding, I am afraid) if this current is a constant value or depends on the load. Intuitively I would assume it to be constant, but would hate to blow up the amp on this assumption.
Assuming the current of 1.2A is correct and constant, R11 would dissipate (P = VI = 0.6 x 1.2 =) 0.7W. I am unsure of the thermal characteristics of the small heatsinks I have (they were no-name brand so no data sheet) but I would expect them to be about 20-30C/W. This should then be sufficient.
Could someone confirm this for me please?
Thanks,
Albert
Old 1st April 2012, 02:16 PM   #12118
Some folk will listen to average levels from their speakers ~10% (-10dB) of maximum output.
Others will be happy with average levels of ~0.1% (-30dB) of maximum output.
Taking -20dB as an example that will suit many Members, then the average output power is 1/4Watt.
That equates to an average output current of 180mAac.
Don't worry about the heating effect in the feedback resistors.
It's the change in resistance due to Tj when transient currents flow that may be a concern.
Similarly the Source Resistors see the bias current as the continuous average loading. The transient heating effect can be ignored.
regards Andrew T.
Old 1st April 2012, 02:35 PM   #12119
F5 power amplifier
Originally Posted by AndrewT View Post
Don't worry about the heating effect in the feedback resistors. It's the change in resistance due to Tj when transient currents flow that may be a concern.
Thanks Andrew, but I am afraid your answer is aimed at a level of understanding I do not have.
I looked up the Caddock datasheet. There is no Tj mentioned. Am I correct to assume that it is the (resistive) film temperature?
Old 1st April 2012, 02:41 PM   #12120
yes.
regards Andrew T.
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright ©1999-2017 diyAudio
