F5 power amplifier
F5 power amplifier
Old 29th March 2012, 06:36 PM   #12101
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
It will sound expensive.
Old 29th March 2012, 06:53 PM   #12102
AudioSan is offline AudioSan  Norway
expensive and damn hot. shorter lifetime on your caps.
the regulators themself has to dissepate around 70W.
that meens a lot higher ambient temp in your chassis.
Old 29th March 2012, 07:24 PM   #12103
a.wayne is offline a.wayne  United States
Sin Bin
Old 29th March 2012, 07:44 PM   #12104
Bksabath is offline Bksabath  United Kingdom
Banned
Originally Posted by wengtech View Post
what will happen if :
1. using a 10000uf/71v to handle 24v rails.
2. using dual 0-36v toroidal trafo regulated into 24v.
does it affect the sound quality?
I will get to what happens in a minute as you ask
First question is do you already have those?
Why regulate trafo back to 24?
What Volts x Amps trafo rating? more than 800?
Because if you do already have them you could send them to me for proper disposal free of charge.
Then what happen will be me building super duper 50 V rails F5 with tanks
50 v rails(35 x1.47) mean biasing mosfets at max 1 amp so maybe 6 N&P pairs and cascoded duble imputs.
with 300 W dissipation (50 X6) I will have to use a fan on my sinks (2 X 80 mm units at about 30 % speed ) but that is a sacrifice I am prepared to make.
Actualy I am saving up for just similar components.
Sound quality will be greatly improved when I am having big party as 1812 vill stop clipping and spoil neigbours enjoiment (speaker protection cut off and put F5 in stand-by for 30 seconds or so)
Old 29th March 2012, 08:00 PM   #12105
EDIT: 120W not 70W.
Old 29th March 2012, 08:06 PM   #12106
Banned
If the heath in the box is a problem dont build the box.
Just stick 4 legs or 3 on the sink and wrap the non fins sides in perforated mesh
cheap to get and easy to cut with decent scisors.
Old 29th March 2012, 08:34 PM   #12107
better to use the power insted then.
insted of warming up the room with it.
Old 29th March 2012, 09:37 PM   #12108
Banned
warm room and class A amplifiers are blessing in Uk
Is normaly raining in here as we have 2 kinds of wheater
coldish rain and warmish rain.
This is what I use
Buy Perforated Sheets Perforated steel sheet,1.7mm dia RS 817-426-0002 online from RS for next day delivery.
Yeah do not let the mosfet sit there at bias VGS just play lauder.
Old 29th March 2012, 09:52 PM   #12109
CanAm Man is offline CanAm Man  United States
Originally Posted by kroyin View Post
The resistors are around .47 ohms (.9 ohms with DMM). More questions to help me with troubleshooting
Are the resistors marked/banded as .47 ohm resistors?
Does your DMM measure them as 0.9 ohms "out of circuit"?
Keep in mind, you may have twice the resistance (0.9 ohms v. .47 ohms) and therefore only half the current flow at the .48 v bias level.
I'd doublecheck those two resistors.
Old 29th March 2012, 09:54 PM   #12110
This is what I use
yes. but i rather turn up the bias then let some regulators heat my room
nice ones
i use this for vents.
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
