| Thread Tools | Search this Thread |
#1191 | |
Hi Patrick,
I completly agree to your definition of "X", indeed one doesn't restrict oneself to inverting gain stages. It's all about wether or not the error signal of one half is feed into the other with the correct polarity and level. I simulated all three variants, the simple Bridge (the nodes in question grounded), Zinsula (nodes connected directly) and yours (nodes cross-connected only). But I couldn't find any significant change in distortion, both looking at the single-ended outputs (ref'd to GND) and the differential ouput, the third harmonic always dominated THD with its stable value. Therefore I guess that the error signal is not cross-fed in the way needed to get the cancellation in the diffential output. Quoting the Master, an indicator if "X" is at work should be: Quote:
- Klaus |
#1192 |
Test Setup :
#1193 |
Measurements :
There is a very small peak of +0.5dB at about 600kHz, but since it was not proper power supply and wiring, I did not bother and left it as is. Full complements to the original circuit creator that it works first time without a hitch, even with all the changes from the original schematics. Patrick |
#1194 |
Slightly OT :
Micromega? Witch one? Any comment on sound? Manu |
#1195 |
>Any comment on sound? As stated above "Stage 1". 11 years old, but too good to throw away. Analogue section completely modified with discrete filter / amplifier stage with balanced output. Sound is OK, but not my reference. Patrick |
#1196 |
Patrick,
pretty cool job you did, congratulations! And thumbs up to Nelson of course, there aren't many simple 4-Transistor amps around that seem to be as good and as robust as this one. BTW, did you run tests with cap loads yet?. I'd be very interessted to see how the step response looks like... - Klaus |
#1197 |
Load is reactive (Stereophile dummy speaker).
I posted the link and photos before on the Solid State Forum. Please search. And no, I do not test with pure capacitive load. It is not realistic, and for me only of academic interests. Patrick |
#1198 | |
Lovely stuff.. |
#1199 | |
#1200 |
diyAudio Editor
balanced
| Currently Active Users Viewing This Thread: 3 (2 members and 1 guests) | |
| Dennis Hui, Bksabath |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 10:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 08:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
| Page generated in 0.27390 seconds (38.76% PHP - 61.24% MySQL) with 11 queries |
