F5 power amplifier
F5 power amplifier
Old 3rd March 2012, 02:07 PM   #11931
triode_al is offline triode_al  Netherlands
triode_al's Avatar
But no feedback across the output; in that sense this 'inverted daulington' looks very similar to the BA3 frontend/BA2 output, here linked in DC - and having a darlingnot at the output.
SPU --> tube MM/RIAA;
Pass buffer -->300B SE + DN2540 CCS/Buffer; --> 165GMF in TQWT
Old 3rd March 2012, 04:56 PM   #11932
flg is offline flg  United States
flg's Avatar
I commented on that idea in the BA-3 thread when is came out regarding coupling directly to the BA-2 Output, but didn't get a large response.
From Post #252
Originally Posted by flg View Post
I was looking at the BA-3 idea and I realized that an alternate connection may be possible?
What if you remove R125 & 126, P102 and C101. Insert the drain connection of Q3 and Q4 in their place.
Would this work? I see where the TL part would then be dealing with 45mA and that would probably not be good. maybe we could lower the values of R127 and 128 to correct for that?
We would possibly be benifitting from the removal of C101 and maybe a reduction in power supply noise getting into the signal?
Any comments?
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Old 3rd March 2012, 08:12 PM   #11933
triode_al's Avatar
I saw that, flg,
But your idea can work if you have the output connection floating, that is: the other side of the speaker goes to to two caps connected to plus and minus rail. 10.000 uF is more than enough.
Well, as such the Evolve circuit does have operating point stabilization: feedback is DC.
Old 4th March 2012, 11:20 AM   #11934
njgale is offline njgale  England
Originally Posted by lhquam View Post
I am looking for 2 or more CViller F5 v1.1 boards. The mosfet spacing of 80mm on those boards is perfect for my heatsinks,. The Cviller F5 v2.0 mosfet spacing is too large at 120mm.
I *think* the F5c boards have 8cm inner mosfet spacing - the tentativeness is that I only have access to the 2009-12-20 rev of the board, which *is* 8cm for the inners. The diyAudio shop only sells a later version (2011-02-09).
Comparison of the two versions of F5 board that I have :-
HTH
cheers
Nick
MadDad
Old 4th March 2012, 02:06 PM   #11935
lhquam is offline lhquam  United States
HTH
cheers
Nick
Interesting. The bottom board you show (F5C v2.0) has MOSFET spacings different from what the DIYAudio Shop shows for P-F5C-2V20 2011-02-09. Yours is clearly the old version of the board.
That board with the 8cm inner MOSFET spacing would work for me. I am looking for either 2 or 4 boards. Are you willing to sell any?
Old 4th March 2012, 03:23 PM   #11936
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
F5 power amplifier
I have two of the 2009-12-20 boards by Cviller from the shop that I am willing to let go of or trade. It has some of signal resistors already on it CMF-55s.
Old 4th March 2012, 04:22 PM   #11937
I going to be stuffing up a dual-output version, so unfortunately not - these two are the only ones I have of this shape and I don't want to play with cascoding just yet.
I rummaged in my box-o-bits and I do have a pair of unused pdaniels boards as well, which look like they'd do 8cm spacing, and I know I won't get round to using them - they're the little ones below
And I see Tea-bag has some of the cviller boards (and he's on the same continent too )
If the pdaniels boards are any use, pls drop me a PM
cheers
Nick
MadDad
Old 4th March 2012, 06:29 PM   #11938
I have 2 Cviller F5 v2.0 2010-10-23 boards I could trade.
I also have 2 Cviller F5c V2.0 2011-02-09 boards I could trade.
There probably isn't much else in my parts pile that you might want, since most of it dates back to the 1960's.
Old 4th March 2012, 06:38 PM   #11939
labjr is offline labjr  United States
Has anyone had a problem with the gold plating on the new boards?
Old 4th March 2012, 06:38 PM   #11940
cheers
Nick
Thanks for the offer, but the Pdaniels boards won't work for the way I intend to mount them as shown in this post:
F5 Turbo Circuit Boards
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
