#11901 | |
What about stray inductance in the connection to one board? How about increasing the gate stoppers? You could add at least a 1K resistor; the inherent feedback reduces the effect of the high capacity anyway. (I have increased it myself and added a trifle of a capacitor too . . ). I assume the power supply is not the problem, being a usual suspect? I once had one channel noisier, came down to imbalance of the power supply caps in the first cell (measured 53.000 uF against 56.000 uF) - that is why I now have a very small first cell. In one channel I noticed it (on scope) .
DAC TDA1541 S1; MC30-Super --> two stage RIAA; SP-6 clone ; 300B PP: 6N7/ECC82, Metalimphy output.
#11902 |
In the Turbo f-5, Mr Pass states that he has increased gain to 22 dB by changing R7-R10 from 100 ohms to 220 ohms. Will this work the same way for the standard F-5? If so, this seems like a reasonable increase. Could the resistors just be changed to these values, 220 ohm, the amp re-biased and good to go? Or is this too much for a non-turbo F-5? Wish I wasnt so chicken, I'd just try it! Soon I will have a second F-5 and I will be a little braver! I have a few blank pairs of Daniels F-5 boards and would like to make this new one a little easier to change boards and so forth out in order to try such things without fear of being left F-5 less.
Russellc
Pass DIY B-1, Pass DIY F-5 |
#11903 |
Has been stated and prooved several times, by ZenMod, Papa himself and a lot of other well-known and well-knowing persons, in this and in other threads, hard to find I know.
Just go for it! |
#11904 | |
Russellc
#11905 | |
I think you could even go higher, get even more gain (and a more stable circuit) but the distortion will be worse. |
#11906 | |
Russellc
#11907 |
I have built the F5 without hum/ almost inaudible hum in the attached photo, it seem like there is a loop for the ground, but it just work fine for me.
Try to isolate the CRC pcb to the chasis when mounting, i don't know will it work, but just try
#11908 | |
The star ground you placed on the bottom of the board may not be doing the same thing. I know this may seem like it can't make a difference , but sometimes it does. My amp hummed in the same conditions that you are describing. If you have a horn speaker system you will have to be even more careful with your grounding. Hope this helps, I chased this for 2 weeks before I got to the star grounding. Rush |
#11909 |
With the information from digi01´s thread understanding star grounding, i have located the hum problem!
On the PSU pcb from Jims Audio is a grounding failure! ![]() ![]() As you could see on the pcb, the amp GND´s left and right are connected direct to the central "star" ground. That gives the ground loop, when the cinch cables are connected. ![]() The correct grounding must look like this (also for 2 channel amp´s) ![]() The GND from each amp channel must be connected together to one point and from there to the star ground. To fix the failure on the PSU pcb from Jims Audio, i made a small modification. ![]() I cut the amp star ground connection on one side of the pcb, ![]() ![]() and connect it direct to the amp GND on the other side. Now both amp GND´s share one point and are connected to the star ground. Result: NO HUM ![]() Thanks to all for the help !!!![]()
Reference TDA1541A DAC project PCB´s / Tube-I-zator PCB / SSHV-Shunt PCB
Stock status in my Blog |
#11910 |
Sent from my iPad using Tapatalk HD
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 10:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 08:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
