#11861 |
While you here
what would be the efect of using mosfets with Ciss of about 2500 pf on F5 they came in TO3P packs which current wise is nice? also dumb..... ![]() o YEAH Last edited by Bksabath; 11th February 2012 at 10:33 PM. |
#11862 |
#11863 | |
piece of cake
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#11864 |
Yeah if one just had a clue of what all tose things with big words mean it would not have to ask dumb questions.Xcnductance may go avay with more gain on decent pre but capacitance may trow spanner in to works.Me prety good with spanners
#11865 | |
you need to observe F5 in isolation xconductance , considering OLG vs. CLG vs. feedback generally-if you lack in xconductance of output sage , or if you have higher than desired capacitance of output stage , you can partially compensate that with increase of xconductance of input stage ...... and way to do that is to double No. of input Jfets or just use 2SJ74P and 2SK170P ; all problems will be solved
#11866 |
Ciss = Cgs + Cgd. Crss = Cgd.
Ever wondered why the P-channel is mounted with it's source to the positive rail, and the N-channel with the source to negative rail ?
Not so much,.......if it says "ZM" in the corner. |
#11867 |
Tanks Zen and Jaco
will have to ponder about that for a while (was looking for smiley with smoke comming out of head as it would be most apropiate LOADS of SMOKE). |
#11868 | |
Speaker return sees heavy currents causing voltage drops on its path that are not welcome on the input ground.
No need of a speaker return on the pcb. Can be wired at main star ground, leaving input ground clean. At least separate ouptut ground path from input ground path. Same for qround side of decoupling caps. Not clean. They need to have their own path to ground. Quote:
#11869 |
Hi people!
I need schematic and PCB for this F5 audio amplifier! Thank you all for help |
#11870 |
Chchyong
Your layout deserved a deeper looking at. It'is very nice all in all. Formula 22 Google "Firstwatt" And search for Cviller's blog on Diyaudio All is there. Last edited by bobodioulasso; 12th February 2012 at 07:55 AM. |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 10:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 08:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
