F5 power amplifier
F5 power amplifier
Old 4th February 2012, 10:57 AM   #11801
Select the jFETs by Idss as recommended. That's all you have to do.
Well, not quite.
I would accurately measure all the resistors and select to ~0.1%, both between upper and lower and between channels.
This makes for reliable current measuring later, if there are problems to be corrected.
regards Andrew T.
Old 4th February 2012, 12:22 PM   #11802
william2001 is offline william2001  United States
william2001's Avatar
I have setup the front end of my recently completed (well very nearly) F5 monoblocks according to what EUVL has suggested here: F5 power amplifier
I used the Toshibas (K1530,J201) on the output but didn't concern myself with any sort of matching there.
Old 4th February 2012, 12:44 PM   #11803
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
F5 power amplifier
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 4th February 2012, 12:55 PM   #11804
Hey, is there an echo in here?
Old 4th February 2012, 01:00 PM   #11805
jackinnj is offline jackinnj  United States
jackinnj's Avatar
F5 power amplifier
Originally Posted by triode_al View Post
who are the suitors then?
the dog will let me know, and it won't be good for them!
Old 4th February 2012, 04:14 PM   #11806
Russellc is offline Russellc  United States
F5 power amplifier
Originally Posted by giuliodido View Post
Hello,
I've not been able to find or to understand an explanation to the need of matching transistors in the original F5 amplifier.
Within a single channel, I "extrapolate" from various diyaudio threads that P and N MOSFETs don't need to be matched (also because they are technically different). But what about the JFETs?
I also "extrapolate" that matching MOSFETs and JFETs between left and right channel is not necessary (probably it's useful if I want to do the same operations to bias the two channels, but I'm not sure about it).
Any help is really appreciated
To operate, there is really no requirement that the parts be matched. I like them all matched, simply because I want both channels to match as close as possible. It just depends on how obsessive you want to be....
russellc
Pass B-1 preamp, Pass F-5 Amp, Pass F-6 Amp, Pass BA-3 Preamp, Pass BA-3 Amp, Pass M-2 amp, Pass Pearl 2 Phono
Old 4th February 2012, 05:43 PM   #11807
Renron is offline Renron  United States
Renron's Avatar
If the parts are mismatched, couldn't some of the discrepancy be compensated for in the bias settings? If a sensitive dB meter was used? Notwithstanding the minimal difference in distortion between channels. ?
Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
"I fired up the prototype. Literally." The Prophet Pass.
Old 4th February 2012, 07:22 PM   #11808
tolikas is offline tolikas
tolikas's Avatar
Originally Posted by Nelson Pass View Post
I see you left room for F5 Turbo parts.
The text will be done in a few days - you will see it next week.
Turbo? Sounds good
If that means more power - same quality, i guess it will be a choice for my second amp, as i am plannig to drift to two-way active system cofiguration.
Best regards.
D.
Old 4th February 2012, 09:54 PM   #11809
Nounours18200 is offline Nounours18200  France
Is the schematics of the F5 Turbo released by Papa ? I heard about it 2 months ago on this forum but I have been very busy since then...
Old 4th February 2012, 10:38 PM   #11810
MASantos is offline MASantos  Portugal
They should be sometime next week.
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
Copyright ©1999-2017 diyAudio
