F5 power amplifier
F5 power amplifier
Old 29th January 2012, 11:29 PM   #11771
pdhanwada is offline pdhanwada
Default Speaker protection pass f5(dual output)
Is it nessacary. After going thru the forum far and wide,
So am I right in assuming that the speaker protection mechanisms we are not confident off.
I have never blown fuses on my B&K7270 I am using it for almost 7 years.
I feel it is less likely that speakers would get damaged because of stabilized(tested) amplifier.
Would like to run on Old speakers for a month later switch it back to New speakers. How does it sound.
I see that the original pass f5 from firstwatt.com has protection. Are these copyrighted.
Others can comment too.
Pandu
Old 29th January 2012, 11:30 PM   #11772
jameshillj is online now jameshillj  Australia
Regarding O/P protection -
My 'diy efforts' are occassionally suffer from mistakes, despite the much repeated checking/testing and as my speakers are the result of much time & effort, adding the extra relays in the signal path is an obvious choice and fortunately, I have not found any sound quality degradation, so far, even testing with the h/phones - other builders might differ, naturally.
[Besides, the P/S Rail C multipliers don't quite charge up together at the same rate so need to delay the load connection for a few minutes for this, and the bias, to settle down]
For the h/phones, I would still like to find a reliable circuit that drops out the relays with a dc offset of less than 100mV, if anyone knows of one .....
Old 30th January 2012, 12:29 AM   #11773
chchyong89 is offline chchyong89  Malaysia
Send a message via MSN to chchyong89
Originally Posted by Nelson Pass View Post
And a note to those who have been waiting patiently, I'm about 10 days
from releasing the F5 Turbo Kraken.
the coming 10 days will not be easy start from this moment!
Old 30th January 2012, 01:32 AM   #11774
Malotron is offline Malotron  United States
Malotron's Avatar
And a note to those who have been waiting patiently, I'm about 10 days from releasing the F5 Turbo Kraken.
10 days... seems like an eternity
Old 30th January 2012, 07:03 AM   #11775
Bksabath is offline Bksabath  United Kingdom
Banned
Try to gogle up NTE7100 while there may also gogle up the amplimo relay.
Old 30th January 2012, 07:44 AM   #11776
triode_al is offline triode_al  Netherlands
triode_al's Avatar
Originally Posted by juma View Post
Are there any valves involved ?
SPU --> tube MC/RIAA;
Pass buffer -->300B SE + DN2540 CCS/Buffer; --> 165GMF in TQWT; working on a HYPEXed sub.
Old 30th January 2012, 08:22 AM   #11777
Thanks Bk - not sure lowest stable dc detection, particularly for h/phones - tricky area.
Old 30th January 2012, 09:05 AM   #11778
Banned
100 mV shuld be plenty to charge up the capacitors
Just play about with the value of the resistors (56K?)
I am new at this and my math is baaaaaaad sorry if I can't help more.
Maybe if you use a dummy load and manage to ofset the amplifier you can get the right values by using a pot worked for me
The spec of the NTE give you the voltages needed to trigher the relay
Old 30th January 2012, 09:13 AM   #11779
Dzius is offline Dzius  Poland
Dzius's Avatar
Default P3 and tuning to 2nd harmonic
I observed very interesting phenomena. Even though I added some distortion i.e. 2nd harmonic and in this way THD is probably worse, but sound is more breathy and clear than before. Not only resonant as one can expect.
Old 30th January 2012, 10:44 AM   #11780
Okay Bk - thanks - will try it out - and the fancy Amplimo relays!
Looking forward to the Turbo details.
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
