F5 power amplifier
F5 power amplifier
Old 22nd January 2012, 09:52 PM   #11721
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
F5 power amplifier
The 3rd harmonic is dependent on the amount of cancellation of 2nd
harmonic, so it is possible to see reduce 3rd in the presence of greater 2nd.
Old 23rd January 2012, 05:41 AM   #11722
Dzius is offline Dzius  Poland
Dzius's Avatar
I used computer as a source, recording and FFT analysis tool.
More specific Audacity program: Audacity: Download for recording and analysis, and Windows Mediaplayer for playing 1kHz signal generated in Audacity.
So there is a chance that spectra are not so fabuluos duo to computer soundcard distortion. Nonetheless it can be used to trim amplifier.
Old 23rd January 2012, 01:05 PM   #11723
jackinnj is offline jackinnj  United States
jackinnj's Avatar
F5 power amplifier
When you run any kind of FFT or analog "narrow bandpass" scan it's useful to establish a couple of baselines -- you can short the RCA's on the input and see whether you're picking up interference from a power supply, video card etc, you can connect the test leads and terminate them in a 50R load and see how much interference is picked up by the cabling. Generally, if these unhelpful artifacts are 30% or less of the fundamental the RMS'ing works out such that you're better than 2-sigmas.
Old 23rd January 2012, 01:26 PM   #11724
kacernator is offline kacernator  Czech Republic
Default Lower value of one source resistor
I know that official F5 amp has one source resistor 0.47 Ohm and other is 0.39 hm (0.47 + 2.4 in paralell). How do I determine which resistor should I lower? The one that is connected to mosfet with higher transconductance?
Old 23rd January 2012, 06:01 PM   #11725
lykkedk is offline lykkedk  Denmark
lykkedk's Avatar
Hello...
I am trying to build a F5, for the hole lot FUN of it
Do i benefit anything, "pairing / matching" the Q1 vs. Q2 to each other ??? (2sk170bl / 2sj74)
Jesper.
DCG3 Dual DCSTB, R2R DAC in build (2 ReflectorD's (+5VDC/+3.3VDC) + SSLV1.1 (+/-12VDC))
AlephJ Mimi! http://www.diyaudio.com/forums/pass-...mimi-mini.html
Old 23rd January 2012, 06:14 PM   #11726
Dzius's Avatar
So that's the noise floor.
Old 24th January 2012, 10:55 AM   #11727
xenob is offline xenob  Austria
Hi Dzius: nice distortion pics.
I recently discovered ARTA and used it to set up my BA-3.
It shows you THD and THD+N in %.
Next thing to do do is check distortion vs frequency (Farina method or in STEPS).
Old 24th January 2012, 01:01 PM   #11728
jackinnj's Avatar
F5 power amplifier
Attachment 262017
Try with the input shorted -- I ran this test a half-dozen times to make sure my eyes weren't fooling me -- although I believe that the numbers below 30Hz or so are bogus as they are well below the threshold of the SYS2722. This is noise referenced to 0dBV.
Bottom graph is an F5 connected to the analyzer, but not to the a.c. line, second test is connected to the power line, but not "ON", third is with the F5 on.
Old 24th January 2012, 03:24 PM   #11729
R.I.P.
Better than -100dB ref 1Vac (0dBV)?
That's equivalent to no individual frequency giving more than 10uVac at the output.
Adding all the frequencies together would give the total noise at the output. Expect <100uVac
I am surprised there is no 3rd harmonic of the 60Hz mains.
regards Andrew T.
Old 24th January 2012, 04:48 PM   #11730
The one and only
F5 power amplifier
I am unaware of this being the official circuit.
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
